So, my IJ has been on and off been doing a watchdog reset when both flippers are hit. Last time I went in there to adjust things I was convinced the J901 connector was super loose fitting and reseating that connector makes the problem go away.
Fast forward to today where on a rainy day decided I was going to replace the IDC on both sides of that cable as it had started doing resets again.
After testing, now both flippers are super weak. Troubleshooting so far:
- Ran Diode test from here, passes
https://pinside.com/pinball/forum/topic/sttng-weak-flippers-1#post-5433517
- Reseated every connector on the fliptronics board as it wouldn't be the first time bumped something loose when removing a connector.
- Reterminated the wires again thinking maybe i had a bad insertion / voltage drop - same results again.
