Is anyone familiar with this game? I'm having a few issues that I'm trying to resolve. First, the GI plug and pins are fried, apparently common for WMS. I'll have the board repinned this week and I'm going 100% LED do I shouldn't have that problem again. Anyway, at the moment the GI is disconnected. I also have no strobe lights, I'm not sure if they are fed from the GI connector or not.
One main problem is that the cooling (shooter) fan runs non-stop. As soon as the game is turned on it's running. I can't believe that's the way it's supposed to be. I found a burned solenoid fuse (2.5 amp slo-blo) replaced it, but it immediately starts to glow when the game is turned on. Shooter isn't engaged, nor is the ball feeder, (only the fan) to my knowledge that's it for solenoids on this game. Any ideas of where to look to try to see why this is happening? I've read where people wired the fan to the ball feeder power line, but I'd rather not do that.
Also, one row of lights (P) is super bright compared to the rest. I mean SUPER bright. Since the hot is on all the time and only ground is applied to make them light, I'm confused as to how that row is getting so much more power than the rest. It's hard to check voltage because even when they are on the lights 'flicker' to simulate lightning I guess. But it's hard to get a good reading of how many watts are going through this line because my meter is bouncing all over the place. Could this be caused by the driver board, or is it more likely a wire is physically touching something else? I've gone through each bulb socket and they look pretty good, I can't see anything touching or out of place at all.
Any help would be highly appreciated. I'm not a solid state guy, I restore EM games so I'm limited on SS knowledge, but I have a bunch of friends that are good with these games. So any thoughts will be relayed to them, it's just an odd machine and nobody is very familiar with it.
