(Topic ID: 251210)
WMS Gulfstream - Playfield fix suggestions
By ArcadeDanger
6 days ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 1 day ago by ArcadeDanger
#1 6 days ago
Hi folks, I got this Gulfstream some months ago, had other plans for it but no time. I decided to set it up and see what condition it was in. Turns out to be in pretty good mechanical shape - had to replace the kick-out-hole shield on left, tighten up the flippers, and replace a few bulbs, but it seems like the game is mechanically all ok.
The play field is worn a bit: down to wood in the center and the kick-out points; there's some lines (planking?) on the right side of the play field, key lines and inserts are worn.
I'd like to do a light fix to make it presentable, specially the parts worn to the wood. What'd be the easiest approach?
Available to me are some small tubes of acrylic paints available, a small spray paint compressor setup too.
#2 6 days ago
For playfield touch ups, the hardest part is matching the sheen (gloss, semi-gloss, egg shell, flat, etc) of the paint. Some people will use the acrylic craft paints that dry flat and then apply a clear over the touched up area. I've had good results using gloss enamel paints like Testors model paints. These paints seem to match the sheen of the playfield paint very closely. You'll need to experiment with different types of paint to see which one will work best. I'll use a large paint mixing stick to create a swatch to test the paint mixture first, and to see how the touch up paint compares to the original playfield paint. There's a lot of info on playfield touch ups and restoring playfield paint on the Web. Check out Vid's Guide on playfield restorations:
https://pinside.com/pinball/forum/topic/vids-guide-to-ultimate-playfield-restoration
#3 1 day ago
fredsmythson Thanks for the link and suggestions. I decided to try to airbrush the area that was worn down to the wood. I prepped it with melamine foam (magic eraser) and alcohol. Used frisket to mask off a smaller area. Mixing the color did not go well, that is definitely an art I'll have to tune - I'll try again with another coat.
I did run into a complication, the frisket pulled up the old clear coat, so now my beach ball players look like they're sunburn peeling (beach joke, haha). Unfortunately peeled up some other areas too.
Is there some clever way to pull up the clear in a controlled manner, or is this a slog of peeling part by part and laying down a new clear?
Gulfstream-Girl-Peeling (resized).jpgGulfstream-CenterGrid-Peeling (resized).jpg
$ 99.00
Pinball Sales
PinBoss Mods
Pinball Pro
$ 84.95
$ 45.00
Just 3D Mods
$ 89.99
€ 12.50
Playfield - Plastics
Multigame
$ 224.99
$ 90.00
Lighting - Under Cabinet
$ 159.99
$ 69.00
The MOD Couple
$ 54.00
$ 30.99
Lee's Parts
$ 19.00
Sparky Pinball
$ 16.95
$ 115.95
$ 209.99
$ 45.00
Vandelay Industries
