(Topic ID: 141674)
Wizard Of Oz - v5.05 - NOW AVAILABLE
By Pinchroma
  • 232 posts
  • 82 Pinsiders participating
  • Latest reply 3 years ago by kjm8888
  • Topic is favorited by 15 Pinsiders
There have been 15 images uploaded to this topic. (View topic image gallery).
There are 232 posts in this topic. You are on page 1 of 5.
14
#1 3 years ago
Version 5.05 is now available. It can be downloaded from the following link:
http://support.jerseyjackpinball.com/downloads/woz/
This is a full release so please refer to our FAQ for information on our how perform a FULL installation. (Fat Formatted 8GB USB Stick Required). If this USB stick was previously used for another full install, please reformat prior to re-use.
FAQ Link:
http://support.jerseyjackpinball.com:8081/helpdesk/WebObjects/Helpdesk.woa/wa/FaqActions/view?faqId=9
RELEASE NOTES:
== Legend ==
+ Addition * Change/bugfix - Note
== Version 5.05 ==
=== Game Code
* Monitor adjustments are now marked as game-restarting.
* Extra ball points are now 15K instead of 25K.
* Default loop champion reduced to 25 from 50.
* Rescue MB base jackpot doubled to 200.
=== Core Code
+ Adjustments can be configured to restart the game now; diag screen will
reflect when this is going to happen.
=== Pindemption(TM) Code
+ NJ rules install.
== Version 5.04 ==
=== Game Code
* Social media page prettied-up.
* 11-letter HSTD support
+ Monitor sizing/offset adjustments.
* Fix crash for timed Pindemption(TM) game > 130 seconds.
+ New LED support.
=== Core Code
* Game halts on missing files now.
+ File errors shown on console screen.
+ NJ rules install.
== Version 5.03 ==
=== Game Code
* Attempt to kickstart Crystal Ball with every command sent now.
* Display bog removed when a LOT of replays/score awards are turned on.
* Capture Dorothy light now blinks when ball will be locked and is solid when
a ball is already locked and will kick out to upper playfield.
+ Asset protection.
+ Tweet-your-game ability via QR code after game ends. Code only shows up
for 5 minutes after a game, but the timer will be reset if there's activity
on the flipper buttons.
+ Social media attract screen.
* Winkie VUK now scores during Haunted Holes. Sorry about that.
+ Multiball resurrection via starting a new multiball during grace period of
an exiting one, or via a grace period Glinda Add-a-Ball award. Melt the
Witch and Somewhere Over the Rainbow do not resurrect any multiballs. Melt
the Witch cannot be resurrected via Add-a-Ball, but SOTR can. No other
multiball can resurrect those 2. Everything else should resurrect
everything else.
+ Fireball Frenzy audits.
+ Fireball Frenzy extra balls. This is controlled by 4 new adjustments:
- "First Extra Ball at" sets the # of successful (blue) shots to light extra
ball. Default is 10, range is 5-25.
- "EB Shot Add Amount" sets how many shots get added to light the next extra
ball. Default is 5, range is 3-50.
- "Maximum FBF Extra Balls" sets how many EBs are allowed to be awarded by
Fireball Frenzy. Default is 5, range is 0-10. If set to 0, no extra balls
will be possible from Fireball Frenzy.
- "FBF Extra Ball Memory" sets whether a FBF lit extra ball will survive to
the next ball or not. Default is ON.
* Edited game credits.
* Significantly reduced HSTD minimums. Note that if you change these, you'll
need to do a Reset High Scores to make the changes show up.
* Ramp lock insert is now subject to light shows.
+ Glinda can now award Add-a-Ball during multiball. This will work only once,
but if a new multiball is started after collecting it, it will be available
again.
+ Glinda can now award Munchkin(TM) time.
* Glinda's "change horses" award now has priority over points.
+ HOADC audits.
+ HOADC extra ball. This is controlled by 2 new adjustments:
- "Horse Extra Ball Level" sets how many horses you need to collect
successfully to light extra ball. Default is 5, can be 4, 5, 6, 7 or OFF.
- "Horse Extra Ball Memory" sets whether extra ball stays lit after draining
* Munchkin Modes now have grace periods and can be resurrected by Glinda
during that time.
* OZ top lane display will not show up during ECMB now except to show a
completed bonus X award.
* Fixed a bug where ECMB might not be relightable.
* Fixed an issue where a Haunted Mode would be "forgotten" if the Haunted
skill shot was made while a Haunted Mode was already running. What happens
now is that you get 30s more Haunted time and 2 value increases for the
current mode.
* Fixed an issue where someone might not get to enter initials for starting
SOTR.
* Melt the Witch will now kill every running mode upon start.
+ "Free Play Dispensing" adjustment: Allows tickets to dispense when game is
set to Free Play. Default is NO.
+ "Service Credit Dispensing" adjustment: Allows tickets to dispense when
game is playing off of a service credit. Default is NO.
+ "Service Credits Tickets" audit. Number of tickets dispensed from service
credit games (this is a subset of "Tickets Dispensed").
=== Core Code
* Fixed ball search during tilt issues - ball search paused on tilt start,
ball will force-end after 4 searches (unless Chase Ball is OFF).
+ Asset protection.
+ Log boot-ups.
+ Added Franken (Swiss Francs) to currency list.
* Fixed time over sound playing when ball had already drained.
* HSTD 5-8 default to 0 credits awarded.
* Fixed trough not taking settle time into account with regards to ball
savers.
=== OS
* Base version is now Ubuntu 14.04, should support gen 1 and gen 2
motherboards.
== Version 5.00 ==
=== Game Code
* Reduced max power setting for jet bumpers.
* Added switch numbers to trough test display.
* Removed TICKET option from Special Award.
* Attract mode altered when Pindemption(TM) is active.
* Fixed credit light sometimes staying on in diag.
* Score display shows time remaining instead of balls if timed game.
+ Timed-game-related choreography.
* No ball save speech during timed game.
* Castle door latch coil test time now matches time used in gameplay.
* Score now shows tickets won when set for Pindemption.
* Many display changes for Pindemption.
* No bonus screens for Pindemption.
+ Game over tickets won display for Pindemption.
* Updated intro movie and quad cross for Pindemption.
* "Shoot throne room" speech no longer fires in grace period.
* Disable status report in Pindemption.
* Melt the Witch altered for Pindemption.
+ Hits to raise Witch adjustment (default 3, range 1-3).
+ Hits to lower Witch adjustment (default 2, range 1-2).
+ YBR Spots adjustment (default 0, range 0-9). Controls how many free
advances on the Yellow Brick Road you get at the start of the game.
* Fixed card reader attract mode movie (wouldn't display more than once).
* Intro movie aborts if game is not active (e.g. entered diag).
+ Video now loops in diag on the Crystal Ball to show it's working.
+ Game Over Music adjustment (default ON).
+ Default payouts adjusted based on Desired Payout Percentage.
+ Attempt to kickstart Crystal Ball in case display had a power glitch and
is sitting in init.
+ Pindemption(TM) system.
+ Pindemption Rules adjustment. Controls how entire game operates (and
enables/disables further Pindemption settings).
+ Ticket value adjustment.
+ Total ticket payout adjustment.
+ Pindemption ticket histograms.
=== Core Code
* Added dedicated switches to Single Switch Test.
* Fixed ball search not running during tilt.
+ Monitor info on bootup.
* Fixed a bug where sounds might stay ducked if the ducker was killed.
* Improved opening of device drivers.
* Fixed switch test grid plotting problem that showed up on some monitors.
* A stuck-closed tilt now dispatches at ball start.
* Fixed an error in sorting for the Ordered LED Test.
+ Left and right flipper audits.
* Error dot defaults to OFF now. When on, moves every few seconds.
+ Ticket mech support.
* TICKET removed from possible award settings.
+ Game Play Type adjustment (BALLS or TIME).
+ Time Per Game adjustment (in seconds - default 45, range 30-300).
+ Timed Game Over Type adjustment. Can be set to:
- SUDDEN DEATH - game is over next time the ball drains.
- SUDDEN TIMER - game is over next drain or when extra timer is up.
- INSTANT DEATH - (default) game is over immediately.
+ Sudden Death Timer adjustment (in seconds - default 10, range 2-15).
* When Sound Test is in RUNNING state, the display now scrolls properly.
* Adjustment values now wrap around when editing.
+ Pindemption Preset.
+ Money Limit adjustment (maximum money game will hold at once).
+ Credit Limit adjustment (maximum credits that may be on game at once).
+ Money Eaten audit (overage lost to the Money Limit).
+ Credits Eaten audit (overage lost to the Credit Limit).
* Pricing levels that violate the Credit Limit aren't considered/honored.
+ Logical ticket accounting (specific values for programming analysis).
+ Money-in Auto-start adjustment (default OFF - controls whether game starts
immediately after sufficient money is inserted for a credit).
+ Flipper Auto-launch adjustment (default OFF, can be OFF, LEFT FLIPPER,
RIGHT FLIPPER, EITHER FLIPPER, BOTH FLIPPERS - controls what flippers can
cause the ball to launch if it is sitting in the shooter lane waiting to
be plunged by the player).
* Default trough fire strength is now 8 (was 18).
#2 3 years ago
w00t! downloading now
#3 3 years ago
Reminder, this is a full release. I recommend backing up your settings and scores before doing the full. It will do a factory reset.
#4 3 years ago
Awesome! Downloading.
WOZ is the best code supported pinball machine of all time!
#5 3 years ago
Quoted from PanzerFreak:
Awesome! Downloading!
I have not been the biggest superfan ever, but it is nice to see this sort of support so far after the release!
#6 3 years ago
Looking forward to an afternoon update! Thanks.
#7 3 years ago
25.0 KB/s - 6.0 MB of 3.8 GB, 2 days left
#8 3 years ago
download complete
#9 3 years ago
Quoted from Pinchroma:
Thank you Alex and team!!!....believe I will tackle Saturday, when I have enough time to save/ double check my settings, etc.
Awesome machine, and it's dialed in perfectly for me....been playing great!!!
#10 3 years ago
Quoted from FalconPunch:
Sorry Falcon. I don't have any available servers in your neck of the woods
If you have one that has an FTP server I would gladly upload the iso to it for you.
#11 3 years ago
Quick question. When you do the settings backup, will that save your highscores and initials in addition to settings?
#12 3 years ago
Im quite sure it does Goren.
#13 3 years ago
It's been a while since I've done a full update but everything went well
#14 3 years ago
Quoted from B9:
Good to hear. Took us a bit to get it out from when we first announced an update was coming but it needed to be right.
#15 3 years ago
All good, The speed is all over the place, it was down to 13k/sec but now its at 1.3mb/sec which is pretty much my max.
Cheers
#16 3 years ago
Can't get to this for a few days, but thanks in advance!
#17 3 years ago
AWESOME!! Thanks team JJP!
#18 3 years ago
Thank you very much!
#19 3 years ago
For the Ruby Red machines, can the display chance from green to red in this update?
#20 3 years ago
While I don't have Woz. It does seem like JJP is head and shoulders above Stern for code support, updates. Stern just gives up on games whenever they feel like, never mind bugs or unfinished wizard modes, no skill shots etc..
I know JJP has more time to mull over its games since its release schedule is one game every 2-3 years. But the fact remains that we have Stern games (while fun) are not as great as they could be since the code is not improved on after a certain point.
IMO this is one reason why I'm now quite hesitant to buy any Stern going forward.
#21 3 years ago
So this is an update from 4.x?
#22 3 years ago
Quoted from cooked71:
Yes, this is the update from 4.11
#23 3 years ago
Quoted from B9:
Wow, thats a pretty major update. Updating tonight for sure.
#24 3 years ago
Quoted from MK6PIN:
Decided to just do it tonight....saved settings, uploaded new version.....all went smoothly....about 30 minutes total, including download time.....all good...thanks again!!! ( wont be tweeting the scores achieved on my test games tonight... ).....mark
#25 3 years ago
Makes me want a WOZ even more than I already do. Maybe when I grow up and can afford it I'll get one.
G
#26 3 years ago
Thanks OP, downloaded and will put on my ruby red tomorrow
#27 3 years ago
Sweet, need to download tomorrow!
#28 3 years ago
For the UNETBOOTIN, are we supposed to run the .exe. file on our PC?
When I downloaded it put these files at the bottom corner. I also do not see the icon option in Step 3 so I assume that would happen after clicking the .exe file?
#29 3 years ago
Is this a partimage that overwrites the boot sector?
#30 3 years ago
Quoted from PinballHelp:
I don't know anything about it other than it says UNETBOOTIN is supposed to be used to move the files to the memory stick. I just don't want to mess up my PC hard drive doing something wrong, because I don't have time right now to deal with anything extra beyond putting the code in my game.
I definitely do not have that black icon the instructions show.
#31 3 years ago
Run unetbootin and just follow the directions exactly as they appear. I just finished the install and get to have a play now!
#32 3 years ago
Ok, it appears to have copied the files onto the flash drive. How do we save the settings in our game before loading the new code? I am pretty sure that is possible with this game for a delta, not sure about a full install.
#33 3 years ago
I know you can copy the settings but I didn't bother. Search the JJP help info though. I reckon I would give it a fresh start.
#34 3 years ago
Question: I purchased my RR in May. Since then, there has been at least one (maybe two) updates that I did not upload to my machine. Will using the link above give me the latest code (including the earlier summer updates)? Thanks in advance!
#35 3 years ago
Quoted from CaptainNavidad:
Yes, the link above is a comprehensive FULL update.
#36 3 years ago
....woot ..woot. Downloading tonight !!!
#37 3 years ago
Yes. It is a full install of everything. So for example if you ever had to replace your harddrive this would be what you would use. You just need a 32gb drive minimum.
#38 3 years ago
Quoted from rai:
Great points. I feel the same way. With Stern there is no guarantee how well a title will be supported code wise and that alone makes buying one of their games a risk. If a games sales are not great to Stern they typically don't offer deep / complete code for the game.
Also, even though some Stern games offer a good amount of modes it doesn't make them interesting. There's a big difference between deep code that is boring and deep code that offers unique / interesting rules.
Personally I think Keith Johnson and Ted Estes are creating the deepest and most interesting rules in pinball today. Thankfully JJP's CEO realizes the importance of deep / interesting code for his customers. Sterns CEO doesn't and therefore only some of their games are offered proper code support (often with programmers working off hours from what I read on here) while other games are simply not completed.
I've mentioned a few times that JJP games offer a lot of value and their commitment to code support only increases the value factor.
#39 3 years ago
Personally I think Keith Johnson creates the deepest and most interesting rules in pinball. Thankfully JJP's CEO realizes the importance of deep / interesting code for his customers. Sterns CEO doesn't and therefore only some of their games are offered proper code support (often with programmers working off hours from what I read on here) while other games are simply not completed.
Not to beat a dead horse. I have XMLE and STLE and for the first 1 to 1.5 years the code was broken. Code was eventually fixed to be good, but if it had been an orphan game like WWE or Avengers who knows? Also the code is still not 100% done and may never be revisited even for known bugs. For example if the ball save kick back on STLE misses a save, the software can know this and just feed the ball back (a virtual save) but it doesn't.
We have a game like Tron which had great code and yet it was still given the tune up to spiff up the graphics and some rule corrections to tighten the game.
I can buy a game that can sit in my house for a decade. If there is a progressive code update and tightening of the code (even if it takes time) it would be a big deal for me, and my $7K machines.
I love IM and won't sell it. But there is a bit that could still be done to improve on the code to bring it up to Tron level.
I'm not saying any game code will ever be perfect, but Stern seems to think if it's OK than it's done. I'd rather see the bar set higher.
I do understand that Stern is coding for 3-4 games a year. And that they like to keep moving. But the pins in my house are here for the long haul. I'd prefer a bit more effort and a bit more code updates.
It's understandable from Stern's perspective that improving code is at the bottom of their to-do list. But there might come a time that OK code is not good enough for me to send any more $7K checks their way. I do like the games I have, but going forward with Spooky, JJP, Heighway (etc..) if they ever start producing games, Stern won't be the only game in town.
I'm sure Stern won't miss me. I'm just one person. But if others feel the same it could make an impact on their bottom line. I understand that polishing code for Stern means spending money. But IMO they need to do more in the code area.
And I am not anti-Stern. I own 7 Stern (down from 8 a few months ago) I bought XMLE, Tron, IMVE, and STLE all in the past 3 years. I'm sure there are much better customers than me. But I'm just saying that's 4 games $24K in the past 3 years.
#40 3 years ago
Awesome! 11 characters for HSTD finally!!
#41 3 years ago
I used a 16GB USB drive and it worked fine.
Gord
#42 3 years ago
Public Thanks to JJP. Jack, Keith, and all those involved!
Polishing a Gem even further, makes WOZ, a stellar product, and sets a new standard, IMO, of code and continued support.
We all know the reasons why some do not like the game, and it isnt even my most played game, but when its on, and a player has had the time to be good enough to get to the "next step", it becomes a unique and thoroughly challenging experience.
Its just harder to get there, then a 3 smack on wolverine in Xmen, and therefore so different then any Stern.
Thrilled to update, and start again.....nothing but several years of joy with this game!
.....and the value when looking at whats coming out these days......a masterpiece!
#43 3 years ago
The 32GB requirement is for a replacement hard drive (if one is ever needed) that stays in the game.
#44 3 years ago
Quoted from herg:
Thanks for the clarification. I misread the initial post.
Gord
#45 3 years ago
Quoted from herg:
Correct
#46 3 years ago
I just updated mine - thanks!! - and noticed one discrepancy: The capture Dorothy (TM) light does blink when capture is enabled but it did not go solid when the ball was captured, even when I had rescue lit and the castle doors open. Not a big deal, just thought I'd point it out.
Also, I don't see it mentioned but the background and text at the bottom of the in-game screen changed to red for RR models (I only have RR so I don't know about ECLE or standard) which is awesome!
#47 3 years ago
Alex, How do we save the settings before loading the new code? I have not had time to try to figure it out because of work.
#48 3 years ago
Quoted from DCFAN:
Turn on the game, put a thumbdrive into the USB cable that is cable tied to the coinbox, go into utilities and select backup/restore - follow the on screen instructions.
#49 3 years ago
Quoted from bobukcat:
What size thumb drive do we need for the backup? I may need to buy another thumbdrive if it is above 2 GB.
#50 3 years ago
Well, I did it...Now I just have to hope that it keeps working....
With my luck its all up in the air now...lol
$ 165.00
Pixels Arcade Games
Pin Mods
Gweem's Mods
$ 48.00
