(Topic ID: 252842)
Witness!!! Mad Max Fury Road Homebrew
By SickNate
4 months ago
  • 190 posts
  • 73 Pinsiders participating
  • Latest reply 1 day ago by ryan1234
  • Topic is favorited by 111 Pinsiders
    There have been 66 images uploaded to this topic. (View topic image gallery).
    There are 190 posts in this topic. You are on page 4 of 4.
    #151 30 days ago
    MD_Pinball_Dude,
    I'm using Fast Pinball so 12v for switches.
    I tested functionality with a fluke voltmeter set to continuity.
    I put my leads from on the lower ring and the bottom of the "piston"
    there was beep the instant the ball made contact with the rings.
    The Fluke uses a 9v battery so 12v should work even better.
    #152 30 days ago
    Quoted from SickNate:
    Got the ramps back from welding awhile ago. I went with 20 gauge and if I could do it over would do 18 or 16.
    I’ll just consider these R&D and if the geometry is good , redo them then.
    Everything is a lot bigger IRL than what I think it will be drawn up in CAD.
    I’m kinda on the fence if I should polish all the metal parts shiny and chrome , or leave them more rugged and apocalypse[quoted image]
    "we will ride shiny and CHROME all the way to the gates of Valhalla!" Was a great line in the movie when they used silver spray paint to paint their mouths. So, a silver powder coat on the ramps might tie into that nicely. Another idea might be to get a printer to print wraps for the ramps simulating the reddish dirt roads in the wasteland maybe even with some of the vehicles printed on them. If the ramps tie into a chase mode in any way that might work. I'm a sucker for chrome but this is such a great theme the options are endless.
    #153 28 days ago
    Quoted from Pinballmike217:
    Exactly this. I don't think you could go wrong with your choice.
    #154 28 days ago
    For the right ramp exit, you could lose the ring end of the wire form to aim the ball down the right orbit. This will limit bouncing around and should result in a clean delivery. Look at the left and right exits for high speed, or bk2k upper to lower wire form.
    Dig reading the progress and all the ideas!
    #155 27 days ago
    CraigC,
    yes I want to do a better job directing the right ramp exit at the upper flipper
    I don't have a lot of height to play with because I'm going under the right ramp.
    I'm afraid if I go too close balls will hit the ramp coming out of the plunger lane.
    Perhaps I should re route it like in this pic
    #156 27 days ago
    Maybe get rid of the shooter lane ramp, and use a flap like Seawitch?
    #157 27 days ago
    Slowly making progress.
    Made the backwood and some lane guides today.
    Feels good to see stuff designed in solid works IRL.
    If I could do this over I’d use all off the shelf parts since it’s my first pin.
    But all the custom stuff is done (Other than playfield) so I’m excited . Gonna try to CNC the playfield next weekend.
    I’m sure a lot of people were rolling their eyes when I said 9 months to complete this.... And I’m right there with them now.
    A custom pin is no joke. Totally worth it though..... I hope
    9B104F28-6E3B-4D32-8E05-FABA3BC27571 (resized).jpegBA0D1361-73F6-4EDA-9533-5AAB824E027F (resized).jpegEBC1F57F-7FC2-4546-987B-C6E010B6FBDC (resized).jpeg
    #158 27 days ago
    CraigC,
    Perhaps I should re route it like in this pic[quoted image]
    Why not try a flanged 4 way intersection? Never been done that I know of. If you put a hump on the ramp section going across and made the intersection big enough, the ball could "jump" the gap, then the right ramp exit could drop straight through with gravity (no jump for that direction and drop right in front of the upper right flipper.
    The only unknown is what percentage of balls would be going fast enough to make the jump successfully, but that could likely be tweaked by ramp angle. And in multiball where it gets busy at the intersection, you could have pinballs colliding on the ramp action-style in a perfectly theme appropriate way.
    #159 27 days ago
    Vireland,
    I actually love this idea. If I can’t make the geometry work and have to redo the ramp (as you can see it’s already made) I will do it this way.
    With the ramp jumping the return wire it’ll go to the upper flipper regardless. And you’ll only get credit for the shot if you make the jump. I wish you said this a month ago before I made the ramp.
    #160 27 days ago
    Vireland,
    Well, I didn't know you were extending that sub return in the redesign!
    But yeah, an action-intersection with a jump one of the directions could be rad if the physics work out, and the ball collisions in multiball would be on-point for the theme. You could detect balls that were knocked off (enter switch, no exit switch) and give points for it so players could be trying to make collisions happen.
    #161 27 days ago
    Quoted from vireland:
    This is an awesome idea. Timing shots from both flippers so that they collide in a designated spot is next level. I’m sure it’d be tough, but what a rad goal for a super jackpot in multiball.
    #162 20 days ago
    Got the lids done on 2 of the diverters.
    Been trying to plan a way for a switch before the diverter for ramp confirm in my head for a little bit . Worked out nicely.
    Got frustrated trying to draw stuff up in cad ... so just started bending wires around . For some stuff that is definitely the way to go.
    Added some inserts on the back wood above the citadel pipes.
    Just 1 diverter And playfield away from being done with the machining.
    ....then the real work starts
    2F3C9809-F6C0-40F9-BBDC-14A6AE8B8C00 (resized).jpeg914312D5-5B41-4CDC-87BB-1E4D07BBF735 (resized).jpeg1494F4BF-DA00-4A16-B745-3E8415E01B58 (resized).jpeg
    #163 20 days ago
    ....then the real work starts[quoted image][quoted image][quoted image]
    For that kind of a tight switch spot, why not just use an opto pair?
    #164 20 days ago
    +1 Optos are sure nice in places you don’t want hang ups or adjustment issues
    Can’t wait to see this on a Playfield!
    #165 20 days ago
    Vireland,
    A bit of thought went into this. I do use an opto pair on the diverter mech to confirm a ball lock at the citadel pipes.
    I changed the scoop to have a ball in the bank to send while waiting for a ball to come in the subway
    (less idle time waiting for a ball you can't see moving)
    I needed to add a switch before the diverter and after a point of no return.
    See attached pic
    I can't have an opto pair above and below in this area because directly below is a subway.
    Also it's wider in this area so the ball won't get stuck.
    The GT 45 degree wall makes it so the ball will roll down toward the citadel pipe even if stopped
    If this wall were straight a ball that just makes the ramp would get stuck.
    Side to side there ain't much room.
    I realize this thing is WAY over engineered ... but I had a vision for Citadel multi ball and I stuck with it.
    #166 20 days ago
    Vireland,
    See attached pic
    Your drawing made me realize that an opto spinner you can't see in one of the turnarounds would be rad to pour on the guzzoline and supercharge your car(s).
    #167 20 days ago
    Vireland,
    Let me get this right....
    I post a mech I designed and made from scratch that does the following :
    Directs ball from ramp to pipe behind back wood
    Diverts ball to subway
    Holds ball for ball lock
    Confirms hold with opto pair
    Confirms ramp with switch.
    You reply that I should have used Optos for ramp confirm
    I reply with a detailed post on why I didn’t use optos.
    You reply I should use a spinner opto.
    #168 19 days ago
    Vireland,
    Well, you advertised yourself as "Sick" Nate...sickness is unrelenting.
    #169 19 days ago
    Touché
    #170 19 days ago
    fantastic work! Luv it!
    #171 17 days ago
    MD_Pinball_Dude,
    OK. I was just thinking way out into the future where you have had 1000s of plays on this machine and tens of thousands of pops. Where the ball touches the post and the base, there will be a very, very small voltage arc and over a very, very long time there might be a carbon (?) ring forming on these locations. You might want to add a diode across the two or a current limiting resistor if you find some weird things going on during testing.
    Honestly, the pop setup looks damn near bullet-proof.
    10
    #172 13 days ago
    Designed the apron today and ordered from oshcut. We'll see how it turns out.
    I was hoping to cut the playfield this weekend but couldn't get router time. I have the program ready to go though.
    #173 13 days ago
    Def polish ramps and lane guides.
    Chrome plating looks crap after a while with ball trails, doesn't happen when polished imo.
    I've had both now only polish.
    #174 13 days ago
    Jakusu,
    I can’t say enough how impressed I am with your Mad Max. Someday I hope to have my pin beside yours at a show.
    #175 13 days ago
    That would be awesome!
    #176 10 days ago
    Plastics done....well they still need art
    -3
    #177 10 days ago
    Screw Trump!! Sick Nate for President!!!
    #178 10 days ago
    I’m used to inputs and outputs for PLCs.
    In the pinball world it’s switches and coils.
    Maybe this is too in the weeds to post
    But I’ll do it anyways. Here is where we stand with I/O now, hopefully it doesn’t have to change much
    MMFR I/O
    Fast Pinball I/O Borads
    board 0 32-08 (1st board in loop)
    board 1 16-16 (2nd board in loop)
    board 2 32-08 (3rd board in loop)
    board 3 08-04 (4th board in loop)
    Lower playfield
    32-08 (1st I/O board after fast controller #0)
    (32 inputs 8 outputs)
    inputs/switches
    0-0 Left flipper button
    0-1 Right flipper button
    0-2 upper flipper button
    0-3 Nate Lower scoop opto1(eject position)
    0-4 Nate Lower scoop opto2(stored position)
    0-5 Target between Nux and lower Scoop "Mothers Milk"
    0-6 Barry opto (top)
    0-7 Larry opto (bottom)
    0-8 Nux target top
    0-9 Nux target middle
    0-10 Nux target bottom
    0-11 NUX motor up switch
    0-12 NUX motor down switch
    0-13 Left outlane rollover "R"
    0-14 Left inlane rollover "O"
    0-15 small target between mid ramp and LL pop "Guzzoline"
    0-16 opto trough jam
    0-17 opto trough 1
    0-18 trough 2 rollover
    0-19 trough 3 rollover
    0-20 trough 4 rollover
    0-21 trough 5 rollover
    0-22 trough 6 rollover
    0-23 trough 7 rollover
    0-24 trough 8 rollover
    0-25 plunger lane rollover
    0-26 Right inlane rollover "A"
    0-27 Right outlane rollover "D"
    0-27 Hidden rollover behind upper flipper
    0-28 small target L of right ramp "Bullets"
    0-29 small target R of right ramp "Aqua Cola"
    0-30
    0-31
    Outputs/Coils
    0-0 Left flipper coil
    0-1 Right flipper coil
    0-2 Upper flipper coil
    0-3 trough eject coil
    0-4 auto plunger coil
    0-5 lower scoop eject coil
    0-6 Lower scoop hold ball coil
    0-7 Nux target motor
    Mid to upper playfield
    16-16 (2nd I/O board after fast controller #1)
    (16 inputs 16 outputs)
    inputs/switches
    1-0 UR pop bumper switch
    1-1 UL pop bumper switch
    1-2 Mid pop bumper switch
    1-3 LL pop bumper switch
    1-4 LR pop bumper switch
    1-5 Left slingshot
    1-6 right slingshot
    1-7 upper r slingshot
    1-8 Target behind Magnet
    1-9 Opto for magnet ball present
    1-10 opto1 eject position upper scoop
    1-11 Opto2 hold position upper scoop
    1-12 Spinner Left
    1-13 Spinner Right
    1-14 Left upper scoop target (LOCK)
    1-15 right upper scoop target (LOAD)
    Outputs/Coils
    1-0 UR pop bumper coil
    1-1 UL pop bumper coil
    1-2 Mid pop bumper coil
    1-3 LL pop bumper coil
    1-4 LR pop bumper coil
    1-5 Left Slingshot
    1-6 Right Slingshot
    1-7 Upper R Slingshot
    1-8 Magnet
    1-9 Dissapearing plunger for NUX multi
    1-10 Justin upper scoop eject ball
    1-11 Justin upper scoop hold ball
    1-12 Flasher 12v LEDs (pops and citadel pipes)
    1-13 Flasher 12v LEDs (Squares under spinners)
    1-14 Left Orbit ball gate
    1-15 Right Orbit Ball gate
    Upper playfield/backboard
    32-08 (3rd I/O board after fast controller #2)
    inputs/switches
    2-0 opto Left citadel pipe ball lock(mid ramp)
    2-1 switch mid ramp made
    2-2 opto mid citadel pipe ball lock(Left/UF)
    2-3 switch left ramp made (UF/mid citadel pipe)
    2-4 opto right citadel pipe ball lock(right ramp)
    2-5 switch right ramp made (r citadel pipe)
    2-6 (reserved citadel ramp spinner)
    2-7
    2-8 Left orbit rollover
    2-9 Newton ball rollover
    2-10 Blood Bag trapped opto
    2-11 upper lane "F"
    2-12 upper lane "U"
    2-13 upper lane "R"
    2-14 upper lane "Y"
    2-15 Right orbit rollover
    2-16 Start key
    2-17 co op/vs
    2-18 orbit / ramp
    2-19 pop /slingshot
    2-20 spinners / targets
    2-21 coin door open
    2-22 (reserved)
    2-23 (reserved)
    2-24 (reserved)
    2-25 (reserved)
    2-26 (reserved)
    2-27 (reserved)
    2-28 (reserved)
    2-29 (reserved)
    2-30 (reserved)
    2-31 (reserved)
    Outputs/coils
    2-0 left citadel pipe/mid ramp appearing plunger coil
    2-1 Mid ramp diverter coil
    2-2 mid citadel pipe/L ramp appearing plunger coil
    2-3 L ramp diverter
    2-4 right citadel pipe/right ramp appearing plunger coil
    2-5 R ramp diverter coil
    2-6 appearing plunger to block orbit for fuel pod lock
    2-7 Black light 12v LEDs
    Cabinet
    08-04 (4th I/O board after fast controller #3)
    (8 inputs 4 outputs)
    inputs/switches
    3-0 coin 1 mech
    3-1 coin 2 mech
    3-2 add credit button
    3-3 service mode button
    3-4 volume up button
    3-5 volume down
    3-7 tilt
    3-7 slam tilt
    outputs/coils
    3-0 shaker motor
    3-1 (reserved)
    3-2 air horn 12v
    3-3 BackGlass LEDs 12v
    #179 10 days ago
    Looking good! Are you planning on using single wound flipper coils though and pwm them to keep them from overheating when holding? I’d advise using dual wound wms style coils.. two drivers per flipper coil. No buzzing, more reliable imo
    #180 10 days ago
    Mbecker,
    Yes single Wound coils and pwm for hold.
    I’m playing around with the idea of turning hold off for multiball or
    Limiting it to 2 or 3 seconds. We’ll see if that is a fun kill or not
    If we need to go to dual and use eos we’ll have to add another board as there aren’t many spare coils/outputs
    You can tell by the list there are three
    Flipper buttons. Not having 2 flippers tied to one switch may help.
    #181 10 days ago
    Mbecker,
    Could be fun on a mode or multiball. Lexy lightspeed does it on a mode and it’s pretty fun for a quick 30+ seconds. Hopefully no problems with pwming them but if you have to add 3 coil outputs an 0804 is pretty cheap anyway.
    #182 3 days ago
    Finally got some machining time
    072CD5A3-3822-4483-8C9C-E52C87D1F445 (resized).jpeg5AD97116-5C7D-4D84-B9DE-96DE0B546C62 (resized).jpeg
    #183 2 days ago
    Apron cover arrived.
    I’ll need to polish/brush it to get rid of the laser spatter but overall am really happy with it.
    #184 2 days ago
    Last diverter done... well minus flycutting the back off.
    #185 2 days ago
    Holy shit.
    #186 2 days ago
    And you are in oceanside! I want to play this. You're more than welcome to come to my house as well. I plan on hosting a tournament soon now that I finally clear coated all my playfields. It took me three months to strip all my games and shoot the clear and I'm neurotic about finishing games. I can't imagine the length of time for what you are doing. Nine months is pretty fast IMO.
    #187 2 days ago
    Great thread. One little note. The pac mans don’t look very threatening/mad maxy.
    #188 1 day ago
    Djshakes,
    Yes I’m in Oceanside. Would love to come in last at your tourney. You’re definitely invited as soon as this sucker is flipping.
    As far as 9 months goes... I thought it was a realistic goal when I set it. Still think it could’ve happened ... would do things differently for a first pin if I could do it over. Or maybe I wouldn’t .
    So far this has been a blast and I would highly recommend doing a homebrew pin to anyone.
    #189 1 day ago
    Amazing thread!
    #190 1 day ago
    It is really looking great!
    Have you thought about anodizing the aluminum to prevent it from breaking down and possibly getting everything dirty? You can get stuff anodized in some really cool colors. !
    Gweem's Mods
    $ 79.00
    $ 7,599.00
    Classic Game Rooms
    Hardware
    $ 26.00
    Pin Monk
    $ 400.00
    Great American Pinball
    $ 36.82
    Pinball-Mods.com
    $ 70.00
    The Pinball Vault
    $ 69.95
    $ 57.95
    PinBoss Mods
    TheDudeMods
    $ 75.00
    $ 36.99
    Lee's Parts
    $ 40.00
    G-Money Mods
    $ 199.99
    $ 76.95
    € 3.70
    $ 109.99
