(Topic ID: 204584)
wiring help for left flipper for creature from tbl
By tomthetank
6 years ago
  • 16 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by LTG
#1 6 years ago
Question is the wires for the left flipper, I don;t want to blow the boards out .I lost paper that i had and dont know which wires go where on the 3 for the flipper coil. I found creature manual on line but don:t understand wiring any help would be great thanks Tom . p.s.enclosed are the pics i need help with thanks you, Tom. also new flipper and coil are pic 1 and 2 are wires for left flipper 3 is the right flipper working(dont know if relevant for left flipper) and pic 4 the wire place for the 2 wires on the long fins for the flipper ( pic 4). any help is appreciated.thanks tom
#2 6 years ago
EOS doesn't matter. Black on one side orange on the other. That switch closed just shorts them together.
#3 6 years ago
Quoted from tomthetank:
#4 6 years ago
Thank you.
#5 6 years ago
zaza always knocks it out of the park with his custom, easy to read images
#6 6 years ago
Quoted from LTG:
#7 6 years ago
Quoted from j_m_:
Used an older image and did some magic tricks with it.
https://pinside.com/pinball/forum/topic/williams-fish-tales-lower-flippers-wont-stay-up-1#post-3958444
#8 6 years ago
Thank you. Just want to ask what you think of wiring and if effected because of different arrangement with new reverse coil set up. One on right was position of other coil /flipper assembly. Pink on left is new assembly thats switched as you can see in pic. Thanks zaza for help. Tom
#9 6 years ago
Look at zaza's picture. Look at the lugs and silver band end of diode. That is with the lugs/base down and coil body going up. Wire your coil just like that.
Then stick the coil in right side up or upside down. Just get the wires in the right spots and don't over think this.
#10 6 years ago
Wire your coil just like your picture with wires ( without stripes ) painted in.
b90f724b00de0a6947724bb7f79d5e15fc97508d (resized).jpgb90f724b00de0a6947724bb7f79d5e15fc97508d (resized).jpg
#11 6 years ago
Here is a picture and I added the color stripes for you.
Incidentally, in this picture. The coil is installed right. Diodes should be up by the plunger end of the bracket. Not by the coil stop, where vibration is harder on the diodes and may break them off.
Originally your coil may have been in wrong. But the wires were still in the right spots.
#12 6 years ago
Quoted from LTG:
thank you
#13 6 years ago
thank you LTG, a little gun shy after frying board. thanks for drawing in the wire order, tom much appreciated
#14 6 years ago
Under stood. Glad I could help.
#15 6 years ago
Quoted from LTG:
LGT, sodered plugged all wires in the cards i got back thesound board repair, and fliptronic 11board. Game works but flippers dont do anything now any idea going over plugs again thanks.have switch error check for #28,35 41,42,43. 28 isd in paid 35 ramp 41 cola, 42 hotdog 43 popcorn thanks
#16 6 years ago
I'd go into Tests - Switch Edge - and check all the switches you listed, push with a finger. And push the flipper buttons in slowly and see if their switches work.
When you blew things up, you may have damaged CPU.
I'd go over any connectors your unplugged and replugged in the backbox. Be sure all are on right, not off a row. Ribbon cable red stripe pin one each end.
$ 69.99
$ 329.99
$ 1,059.00
$ 150.00
$ 5.00
€ 24.50
Pin-Decals
Trade
Machine - For Trade
East Rutherford, NJ
$ 9.95
$ 250.00
Professor Pinball
West Chicago, IL
€ 25.00
PPmods
€ 99.00
Lighting - Under Cabinet
Watssapen shop
8,000
Portland, ME
YouBentMyWookie
$ 45.95
Mitchell Lighting
$ 29.95
Mitchell Lighting
Metal-Mods
€ 24.00
$ 549.00
Juz PINBALL Mods
$ 280.00
Avid Creations Wireforms
7,600
Anaheim, CA
This page was printed from https://pinside.com/pinball/forum/topic/wiring-help-for-left-flipper-for-creature-from-tbl and we tried optimising it for printing. Some page elements may have been deliberately hidden.
