Hi I have to replace my control board and the wiring to those connectors has been soldered to the board. I just need to check that the hack job placed the wires correctly for replacement plugs. Thanks
***BUMP***
Please elaborate though on what type of information or assistance you need? I could not tell from your initial post
The connector plugs have been cut off. I am looking for the wiring diagram that shows the locations of each wire on the 19 pin A1-J6 and the 10 pin A1-J5. Just want to make sure of the wire locations before I put in the new connector plugs. Thanks
In that case, any System 80 wiring diagram of A1J6 will work. They all use the same assigned colors and locations. Did you try PinWiki for the wire colors?
Hi PinWiki shows a color chart but not the wire locations. The diagram of the control board only shows the plugs but not the wires. Still tring to find them. Thanks
A1J5 coin door switch wire colors and postitions:
Pin 1. blue-purple-purple, return 7
Pin 2. yellow-black-black, strobe 0
Pin 3. yellow-brown-brown, strobe 1
Pin 4. yellow-red-red, strobe 2
Pin 5. yellow-orange-orange, strobe 3
Pin 6. yellow-yellow-yellow, strobe 4
Pin 7. yellow-green-green, strobe 5
Pin 8. blue-blue-blue, return 6
Pin 9. yellow-purple-purple, strobe 7
Pin 10. purple-black-black, slam switch
A1J6 playfield switch wire colors and positions:
Pin 1. yellow-black-black, strobe 0
Pin 2. yellow-brown-brown, strobe 1
Pin 3. yellow-red-red, strobe 2
Pin 4. yellow-orange-orange, strobe 3
Pin 5. yellow-yellow-yellow, strobe 4
Pin 6. yellow-green-green, strobe 5
Pin 7. yellow-blue-blue, strobe 6
Pin 8. yellow-purple-purple, strobe 7
Pin 9. green, ground for pop bumper boards
Pin 10. blue-black-black, return 0
Pin 11. blue-brown-brown, return 1
Pin 12. blue-red-red, return 2
Pin 13. blue-orange-orange, return 3
Pin 14. blue-yellow-yellow, return 4
Pin 15. blue-green-green, return 5
Pin 16. blue-blue-blue, return 6
Pin 17. blue-purple-purple, return 7
Pin 18. blue-slate-slate, 5VDC to pop bumper boards
Pin 19. spare
System 80, not just a job, it's an adventure
Sorry haven't been in to check. The wires for the A1-J5 are correct on my machine but on the A1-J6 there are no wires for pins 6-8, pin 9 is white and no wire for pin 17. Whats your thoughts on that? Thanks so much blownfuse.
Hi, I can't comment on your specific application regarding the missing wires. However, pin 9 being white can be correct for ground. Pretty easy to verify that the white wire indeed goes to ground.
Gottlieb used white color for ground wire in a number of machine applications.
Quoted from Crazyjc:A1-J6 there are no wires for pins 6-8,
The game may not use strobes 5 , 6 and 7 and return 7. So no wires in the harness. Seen this before with sys 80 and sys1
Exactly, I just listed the general wire colors used in those connectors. On specific games, they sometimes aren't there because they aren't used. You're welcome Crazyjc.
Quoted from pdman:The game may not use strobes 5 , 6 and 7 and return 7. So no wires in the harness. Seen this before with sys 80 and sys1
This page was printed from https://pinside.com/pinball/forum/topic/wiring-diagram-for-81-gottlieb-volcano-a1-j5-and-a1-j6 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
