(Topic ID: 268496)
Wires too short after rebuilding connectors
By bobnatlanta
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by dasvis
    #1 3 years ago
    The problem connector is J3 on the Rectifier. The wires for the connectors leading away and up the right hand side of the head to the SDB are resting against the heat sinks on the bridges. Not enough slack to tack the harness to the backbox. And I swear, I clipped wires at the pin, and only stripped 1/8" off for the new connector. Any suggestions for dealing with this?
    #2 3 years ago
    Heat shrink tubing to protect the wires from the heat?
    #3 3 years ago
    Solved! P5 connector has enough tension to hold the wires clear of the heat sinks.
    #4 3 years ago
    Quoted from bobnatlanta:
    I would put some small zip ties on those loose wire bundles to neaten them up a little.
    This page was printed from https://pinside.com/pinball/forum/topic/wires-too-short-after-rebuilding-connectors and we tried optimising it for printing. Some page elements may have been deliberately hidden.
