(Topic ID: 177540)
Wire gates for Flash playfield
By Brian_G
5 years ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 5 years ago by Brian_G
#1 5 years ago
I have a question about the two wire gates on the Flash playfield and am trying to determine if I have an incorrect wire gate, one of my wire gates is broken, or my wire gates have been swapped.
I'm observing an occasional stuck ball on the wire gate located where the ball enters the playfield. Upon closer examination, I noticed that there is a nick on the chrome on the ball gate itself that seems to match the shape of the other wire gate (the piece of metal that is turned down preventing travel back to the plunger/shooter rod.
Have these two wire gates been swapped by a previous owner? Are they identical wire gates on any of your machines?
Can someone with a Flash wisdom comment?
Thanks.
Brian
#2 5 years ago
Your shooter lane wire gate is broken.
http://www.marcospecialties.com/pinball-parts/12-6511
(or buy wire and a wire bending kit)
#3 5 years ago
Thank you. Does your wire gate at the top only allow for ball travel in one direction? I had suspected that they were swapped.
#4 5 years ago
I think the shooter lane wire is installed wrong, I don't think it is broken. The lower end has a wire that I can just see in your photo that is bent down and is currently on the launcher side of the gate. If you look on the opposite side of the chrome part, you can see a nick where that down part should go and hit (thus the nick). You probably need to remove the wire from the chrome by slightly bending it, then move it so that the down end is now on the outside. Hope that makes sense. I can take a photo later this evening, but looking (and moving by hand) the top gate (which looks ok) will hopefully help understand how the other one should work.
#5 5 years ago
The shooter lane wire doesn't have the bend and the long piece like the other gate does. It's a poor angle for the photo. There really isn't a bent down wire, which led to oohlou's comment about it being broken.
The real reason that I assumed that they were swapped was that the wire gate at the top of the playfield seemed to jut out more than I would have expected. Interestingly, I did swap them late last week and the performance on both was better. Nevertheless, I certainly appreciate the info. I did check the manual and found that they are labelled as the same part number, 12A-6511.
Tools
Pincoder Store
2,500 (OBO)
San Carlos, CA
1,200
Tacoma, WA
$ 11.00
$ 14.00
2,450 (OBO)
Scottsdale, AZ
$ 27.95
$ 9.95
Great pinball charity
Pinball Edu
