(Topic ID: 134059)
Wire Gate Material
By TomGWI
8 years ago
  • 10 posts
  • 10 Pinsiders participating
  • Latest reply 8 years ago by cal50
    #1 8 years ago
    One of the gates broke on my game. What type of wire and thickness is normally used for one way wire gates?
    #3 8 years ago
    I just go down to Home Depot and get a universal spring with the same thickness wire. .Just cut off the straight wire end of the spring and use the old gate as a template.Needlenose pliers work good to bend it into shape.
    #5 8 years ago
    I also use Piano Wire...works great and seems to hold up over time.
    #6 8 years ago
    I would not think the hanger wire would be stiff enough. Most hobby shops will have piano wire if you want to pick it up locally.
    #7 8 years ago
    Another thing that works perfectly is bicycle spokes. One old wheel from a trashed bike and you're set for life with gate material.
    #8 8 years ago
    Quoted from terryb:
    Right.
    The piano wire is tempered so it springs back and keeps it's shape.
    #9 8 years ago
    Yup piano wire works great, my local Ma and Pa hardware store has it in stock in various gauges, worth a phone call.
    #10 8 years ago
    If you have a welding supply place or a welder friend stainless steel TIG welding rod works nice and will not rust.
    This page was printed from https://pinside.com/pinball/forum/topic/wire-gate-material and we tried optimising it for printing. Some page elements may have been deliberately hidden.
