I'm having some problems with the wire ball guide on my Congo - the wire guide that's in the left outlane. Sorry - probably not using the right terminology. I'm going to blame that on the fact that I'm a girl.
Anyway, as you can hopefully see from the photo below, the top of the wire ball guide keeps popping out of the hole in the playfield (the hole in the playfield is between the "Z" and "I" inserts and in the photo you can hopefully see that the wire guide has popped out and is sitting just to the left of the hole instead of in the hole). I've pushed it in a few times but it doesn't want to stay. How do I make it stay? Is there a piece that goes under the playfield that holds the wire guide in place that I'm missing?
