I have a T2 with two failed GI strings that I can't for the life of me troubleshoot. The two strings are the Green ("CPU") and the Yellow (Right Playfield).
Summary of current diagnostics:
There is power to J115 on all power pins 6-12.
All fuses are intact
Continuity from J115 to the Triacs, from the triacs to J120/J121, and from J120/121 to the fuse blocks all tests fine.
Continuity through the playfield wiring tests fine.
Now the strange part:
Voltage to Triac Q14 (yellow) and Q16 (green) is normal (7-ish volts)
Voltage at the J120 pin for the yellow circuit (pin 3) is 1.6 at brightness 1, 2.7 at brightness 8, and 2.3 when it's supposed to be off (when the test function is on a different string), and 0 when the connector is plugged in.
Voltage at the J120 pin for the green circuit (pin 5) is 2.0 at brightness 1, 2.5 at brightness 8, and 1.7 when the connector is connected although the lights don't illuminate at all.
I'll admit that I haven't tested every light in the right playfield, but I have tested the entire CPU string and there are no shorted bulb sockets or burnt out bulbs.
Additionally, both of these circuits lights up just fine when I jump AC power from one of the good circuits (left playfield, upper inset etc)
I had previously replaced the Q14 triac thinking it was the culprit with no success.
All of the transistors and resistors seem to test fine with the multimeter.
Does it sound like the 74LS374 is failing? I don't have a logic probe so I can't reliably test it.
Otherwise I am out of ideas--I can't see why there would be low voltage available to the J120 but not even a glimmer of illumination from the bulbs.
Thanks for your help!!
