(Topic ID: 311439)
Williams Triple Strike - Doesn’t Score
By TheCnyPinGuy
2 years ago
#1 2 years ago
Hi Folks
This was semi posted on EM pinball on FB but after an original issue was solved
So stating fresh topic
On WMS 1975 Triple Strike
The game does Not Score any points Nor Chimes work
The game resets and you can play your 5 balls all the way down to Game Over
Flippers work
Slings / pop bumper
Drops
Adds Bonus
Just not score or chimes
I was guided by Fun with Pinball to check the
Tilt / Reset Relay / Game Over to ensure all 3 are switches are closed and after inspection, they are closed and appear working accordingly
But still no scoring or chimes
If I manually add a score they all do reset to 0 before serving a ball
Any help would be greatly appreciated
I feel it’s something very minor I’m over looking to have this feature work
James
#2 2 years ago
What happens if you manually activate the 10, 100, or 1000 Point relays in the backbox?
#3 2 years ago
Nothing at all
#4 2 years ago
I would unplug and re-plug the jones plug in the head.
Check for broken wires on both the male/female ends.
Focus on the Yellow, Red and Black wires.
I suspect the Red wire, because the score reset is powered by the Black wire, where as the point relays are controlled by the red.
When you add a game does the credit wheel decrease?
Check the coils that use the red wire in the head for any broken solder joints (Give the wire a gentle tug).
#5 2 years ago
Good opportunity to use the 2 lightbulbs in series test rig to follow the wires through the path. I’d start with the 10 point relay. Does the relay itself get power? If not, work one of the two wires back through the circuit. There should be places in the backbox where you can pick up the red, black, and yellow wires to make sure they’re hot. That takes all the switches out of the picture. The jones plugs are the obvious suspects, both in the backbox and on the motor board. But I’ve run into plenty of cases where it’s a solder tab to the plug socket or a tie point where one of the common wires branches off.
You’ll find it. Good luck,
Dave
#6 2 years ago
Quoted from dgAmpGuy:
Dave
I will take a look
but if I put a manual score on the game once I hit the start button they all reset to zero so I assume they are getting some kind of power to the coils on the score reels
I am not going to give up as it deserves the respect it’s been lacking for many years
#7 2 years ago
There is power getting to the reset coil and the score reels fed by the Black wire.
But it sounds like you are not getting power to the 10, 100, 1k, 10k point relay coils. These are fed by the Red wire.
Because the playfield appears to be working. I would focus on the backbox and its connections.
The other place to check would be the Tilt relay to ensure the red wires are connected - there maybe two and one maybe loose.
#8 2 years ago
Quoted from ArgosySK:
Would the chimes be in sync with the power were missing to the score reels or is that a separate concern
#9 2 years ago
The chimes are energized by the yellow wire through a different contact on the 10, 100, 1000 point relays.
#10 2 years ago
Okay folks something weird has occurred with Triple Strike
Doing nothing to the games mech panel or head
Played a game and Now 100s reel / chime work
The 10s & 1000s - still nothing at all
I will take a better look when I have time and appreciate everyone’s help
$ 24.98
$ 3.00
965
Chesapeake, VA
This page was printed from https://pinside.com/pinball/forum/topic/williams-triple-strike-doesnt-score- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
