Weird problem- Kick out, ball return and Z drop target on same circuit often do not respond. Sometimes if I bang on the side of the back box they immediately start working. Have checked switches, wiring, harness plug on driver board and when I have run diagnostics all solenoids fire as expected. One time when I left the ball sit in the kick out hole for about a minute without doing anything else it then all of the sudden kicked out as expected and then everything worked fine for remainder of that game. Next time I started a game, same problem occurred but leaving the ball in the kick out for a couple minutes did not make a difference. Seems to be an inconsistent issue, sometimes working fine, sometimes not working. Any suggestions as to what may be causing this issue or ideas that I might try to resolve this issue? It only happen on the one circuit, all other solenoids on other circuits are working fine.
