the outhole relay may power when you turn the game on and wake it up, but the ball release coil should not power and kick the ball to the shooter when the game over relay is tripped.
so ... turn on the game and verify the game over relay is tripped and the lock relay is not powered. Hit the left flipper button and the lock relay should power, but a ball should not leave the outhole.
if the game over relay is tripped, the switch on it is correctly open (BLUE-Y-W to RED) and you still get a ball, then you have to look for some non-obvious path that is connecting the ball release coil power to the transformer.
tmi:
pushing the left flipper button powers the lock relay. The lock relay then stays powered forever assuming you don't kick the cabinet too hard and don't turn off the power.
the game over relay is a trip relay. Once it's tripped, much of the game is dead per markg's schematic chunk he posted. Match light is on and other game over lighting is on. This is not recoverable except by manually untripping the game over relay or resetting the game.
if you hold closed the left flipper switch or misadjust a lock relay switch always closed, then when you turn on the game it's a race between the lock relay powering and the game over relay tripping. The game over tripping is supposed to always win.
some games didn't have the left flipper wake up ... the lock relay just powered when the game was turned on and it was always a race. The game over relay won (tripped) because its coil was faster acting.
in any case, is you aren't messing around and just turn on the game, the game over relay on time travel and gulfstream should trip. If it doesn't, then you have the chance of being in an inconsistent game state.
