I'm working on a Williams Touchdown machine. When you start a new game, the ones, tens and hundreds wheels all return to zero. The thousands wheel will only return to zero if it is at nine when you start the game. Otherwise, it stays on whatever number it was at when the last game ended. I looked over the schematic and can't even find a reference to the 1000s wheel. All the other score wheels have three position switches, which are described in the manual. The switch positions change when the score wheel is at 0, 1 thru 8 and 9. The 1000s only has two position switches. 0 and 9. Thoughts?
