Hi Walt
great - You could fix the other issue --- and I move "residual magnetism" from category "heard of" to "actually encountered" (well, long distance encountered).
ipdb has NO paperwork to Toledo - do You have the paperwork ? I say: To every pin there should be a PAPER schematics and a PAPER manual - stored below the cashbox in the pin.
The rather modern EM-pins have a feature I do not really like - it makes the pin more complicated. The feature is: EVERY new, given ball starts with ONE bonus given to the Bonus-Ladder.
I show stuff from (ipdb) Satin Doll (having this feature) - lets take it as an example in reading schematics. YOU toggle-off the pin and YOU manually put some Bonus on the Bonus-Counter (mounted most-likely on the underneath-side of the playfield) - YOU manually TRIP the Game-Over-Relay - YOU toggle-on and start a new game
The Coin-Relay (better name would be: Start-Relay) does actuate - JPG, red-1 therefore is closed, through "2" (tripped G.O.-Relay) the RESET-RELAY ("3") is activated - establishes Self-Hold-Current ("4") and the closed switches "5a" and "5b" ((("5a" is the stuff with the Score-Drums resetting - I do NOT write about this stuff))).
Yes, "5b" IS closed because "Bonus-Relay, '9' " is activated (through "7", "8") and "9" has established Self-Hold-Current "10" - keeps pulling because "Bonus-Unit, "11" is not yet at Zero - means: "11 is closed". The pulling Bonus-Relay and the turning Score-Motor PULSING make ("12, 13, 14") the "15" step DOWN (... 5 bonus, 4 bonus, 3 bonus, 2 bonus, 1 bonus then Zero Bonus).
Through "16" and Bonus-Unit reaching Zero: "17" closes and makes the Outhole-Relay ("18") pull - it establishes Self-Hold-Current ("19") - throws a switch "20" and through "21" the ball is kicked "22" over to the shooter alley. Shortly after (turning Score-Motor) the "23", "24" makes the (not loved) "stepping '25', the Bonus-Ladder UP to 'one Bonus is given' ".
The "26" and "27" are for: You have lost a played ball --- the Bonus-Ladder stepping-down shall be started.
Walt look in Your pin - what is done of the stuff mentioned above - I am interested in Reset-Relay pulling-in AND let-go, the stepping of the Bonus-Ladder , Bonus-Relay pull-in and let-go - Outhole-Relay, Ball-Release (Kicker), Score-Motor --- write about, greetings Rolf.
