New! Dark mode!
(Topic ID: 231198)
Williams Terminator 2 DMD Vertical Lines
By mcccunej
1 year ago
  • 19 posts
  • 11 Pinsiders participating
  • Latest reply 1 year ago by Hawk007
There have been 7 images uploaded to this topic. (View topic image gallery).
#1 1 year ago
I just got a 1991 Terminator 2 machine from my in-laws. For some time it has had vertical lines running through the DMD making it impossible to read scores or access the config screens. I'm pretty comfortable with all things electrical and mechanical, but not much experience with pinball machines. I've tried replacing all of the ribbon cables since it sounds like that's a common failure point, but the problem remains. Any suggestions for next steps?
#2 1 year ago
I think you have done the obvious first step (and the only thing I know to suggest).
I hope someone with more knowledge than I have can give you the next step to try.
#3 1 year ago
Is your games GI out? Bad box looks dark. Good to check the GI connectors for burns on J120 J121 on power driver board.
#4 1 year ago
Quoted from RVApinballer:
Good eye. Half of the GI lights were out. It was just a loose wire. So, a problem was fixed, but unfortunately not the DMD.
#5 1 year ago
do you have another game you could swap out the A/V board with?
What dose it look like with the ribbon cable un-plugged?
#6 1 year ago
Now I am not familiar with Terminator 2, I did have a Black Rose that had vertical lines on the DMD. I had to get new ribbon cables, which fixed the issue. Maybe try reseating?
#7 1 year ago
Quoted from Captain-Flint:
I think he did - next step would be to swap dmd boards (if you have another)
#8 1 year ago
swap DMD boards, or replace the RAM chip on yours. Recently had something similar (not exactly the same) on a Fish Tales. RAM fixed it.
#9 1 year ago
Try Reseating your game ROMs.
I had this issue on my t2 when I owned it. Reseating the ROMs fixed it
I initially tried the ribbon cables, and no luck.
#10 1 year ago
Reseat this ribbon cable at all 3 board connections T2 not having the fliptronix board).Ribbon cable reseating (resized).jpg
#11 1 year ago
It could take 2 or 3 reseats before it acts correct.
#12 1 year ago
I recall that in some cases when I was reseating the cable I was not pushing the connector all of the way down. Obviously, you have to be careful not to push too hard, but just something to consider.
#13 1 year ago
I tried reseating everything again, including the ROM chips to no avail. All the connections look surprisingly clean to my eye. I only have the one machine, so swapping parts isn't a workable option for me. I've been considering upgrading to a color DMD, so I went ahead and ordered a replacement Rottendog DMD controller and a LED color DMD. Hopefully that will resolve the issue. I'll update you all on Friday when they arrive.
Thanks to everyone for the suggestions!
#14 1 year ago
aww too bad someone close to you or yourself does not have another dmd to try or dmd controller board. I bet its the ram on the dmd controller board. If your not going to repair it swap the controller first.
Seen that lots. Same as bad caps but that usually causes rolling. Cables are number 1 and as you tried reseating them along with replacing them so we can rule them out.
Little tip......make sure your dmd controller is 100 percent before plugging in your new display!
no sense potentially hurting a new display..
Good luck and cheers
#15 1 year ago
Quoted from Hawk007:
My stuff arrived a day early, so I just got it installed. I replaced the DMD controller first as you suggested and it does appear to have resolved the vertical lines!
Removing the old controller and getting a look at the back side makes it pretty apparent that there's probably a failure in the lower, high voltage section. The PCB looks pretty crispy.
After replacing the controller, the DMD was still making a high pitched squeal and I can't remember if it's normal or not. No matter, because I also installed my new ColorDMD! It really does make this old game seem new again and I'm quite happy with the purchase so far.
I managed to fix a few other problems it had tonight too, so I think it's officially playable now! One thing I'm not sure how to fix is that it almost always kicks 2 balls out of the trough to start the game instead of 1, but I'll start a new topic for that.
Thanks everyone!
#16 1 year ago
In future, if you see display issues like this, run a display test from the test menu. This will test the integrated circuits on the display controller board and will report any issues. This looks like a simple video RAM issue and could have been as simple as a $1 integrated circuit replacement. The burned section on the rear of the board was probably not related as high voltage problems usually effect the entire display rather than specific vertical segments.
#17 1 year ago
Quoted from arolden:
Good advice, but the vertical lines made the display unreadable to the point that I couldn't navigate the menus. Now that I have spare parts on hand, I do intend to go back and see if I can get the old controller working, but I was trying to get the machine functional as quickly as possible as I'll have a bunch of people at the house over the holidays.
#18 1 year ago
Quoted from mcccunej:
This is exactly why I suggested replacing the boards as opposed to using the test menu because once display issues get bad its tough if not impossible to read . Good on you for fixing it. Color dmd's are amazing.
As mentioned above...Your original controller merely needs a ram replacement and a 7 - 10 dollar high voltage rebuild and its good to go. Some dmd's make noise with certain power supplies. If you rebuilt the original I bet it would be much quieter.
Time to play. You'll be back! Sorry had to say it.
#19 1 year ago
as for your Ball / switch issue check the switch test and see what does or does not work. Use the ball to test switches as your finger is inaccurate. You will find your problem in moments. As mentioned above the internal software and tests are your friend and should be your go to when you have a problem.
Let me know what u find.
Cheers
$ 12.00
