(Topic ID: 156168)
Williams Teacher's Pet Flipper Bushing Holes
By monsonb
  • 10 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by monsonb
#1 3 years ago
The left flipper on my machine started dragging across the playfield tonight, so I checked underneath. The previous owner had installed a larger wood screw to hold the bushing tight, but it had come loose. The others weren't in much better shape, and I couldn't get them tight. I tried toothpicks, but that didn't help.
I'm thinking I'll just rotate the bushing to solid wood and drill new holes. It will throw off the return spring tension between the two flippers slightly , but I can live with that.
Does this make sense, or does someone have a better solution?
Thanks for any input.
#2 3 years ago
Clean it right out and use plastibond. It can be drilled and screwed just like wood and is very, very strong.
I hope you can get this in U S of A
#3 3 years ago
Can't get plastibond around here, so I rotated the bushing, drilled new holes, and installed new screws.
Seems to have solved the problem.
#4 3 years ago
If it's fixed to your liking and works leave it. If not, I would suggest Bondo or Quick Wood putty. (I believe that's the name.) I've used it before p/Cliffys recommendation to fill in/around a kick out hole on Getaway and it worked great and easy to use.
#6 3 years ago
Quoted from Cash_Riprock:
BUT remember you want the FIBERGLASS Bondo, not the body filler stuff.
#7 3 years ago
Quoted from vid1900:
Where were you guys yesterday?
The left flipper seems to work fine now, and I don't notice a difference between the two flippers. If it starts to feel wrong, then I'll give your suggestions a try. I can always fill the new holes, too.
Thanks.
#8 3 years ago
I don't see a problem with the way you fixed it, in fact I thought it was a good idea.
The part works the same way no matter how you look at it, 360 degrees.
And when you encounter stripped out holes again... use something stronger than toothpicks.
I use popsicle sticks and they work fine, make sure to completely fill the hole.
A lot of people like to use bamboo skewers.
I'm sure they work fine too, might even be better due to their strong tensile strength.
#9 3 years ago
Your solution is just fine - should be able to play it 30 more years on that fix........or you can trade/sell it to me when you tire of it
I use toothpicks or bamboo skewers depending on the size of the hole I need to fill.
#10 3 years ago
Quoted from Pinballprowess:
Quoted from hoov:
Cool! Thanks. I thought my idea was solid.
$ 50.00
$ 229.99
Apparel - Unisex
Pinball Wheezer
$ 3.00
Doc's Pinball Shop
$ 400.00
Great American Pinball
$ 19.95
$ 22.00
Yorktown Parts and Equip
$ 6.95
