New! Dark mode!
(Topic ID: 260489)
Williams Taxi doesn’t boot on first power up
By Flasher
9 months ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 9 months ago by mikat11
  • Taxi Williams, 1988
#1 9 months ago
Hi PSers,
I recently acquired a neglected Williams Taxi that doesn’t boot up on the first flip of the power switch. Some lighting comes on but that’s it. If I toggle the switch off and back on the machine plays perfectly with no errors.
Boards and batteries look great actually. Fuses are good.
Any ideas? Thanks in advance.
#2 9 months ago
Can you enter a setting (free play let’s say) and then shut the machine off for sometime. Then get it to boot up again the way you say and the settings is still saved?
Mike V
#3 9 months ago
I had a similar problem on Earthshaker. Fixed it by replacing a capacitor on the MPU. C30 I believe.
#4 9 months ago
Quoted from RacingPin:
Mike V
Yes. Batts are saving high scores and free play.
#5 9 months ago
Quoted from RonSwanson:
Thanks. I’ll investigate that.
FWIW on the first flip of the switch, GI is the only thing that goes on.
#6 9 months ago
Find the 5 volt test point on the power supply board and MPU board. Then turn the machine on. Check voltage. Is the 5 volts reading less than 5 volts ? Keep checking to see if the voltage slowly rises to normal. If so then you probably have worn out capacitors somewhere in the 5 volt circuit.A common problem on older games.
$ 17.00
Metal-Mods
$ 12.00
$ 279.95
Pin Stadium Pinball Mods
$ 54.99
$ 94.95
$ 29.99
Lithia Springs, GA
