I've got a Williams System 9 board in a Sorcerer that will only boot into audits mode. I had previously installed a coin cell battery holder back when it was working fine. I have the proper voltage at pin 24 of U18 (RAM). If I hit the diagnostic switch on the CPU it shows a 5.
I thought perhaps the RAM was bad so I removed it and installed an 6116 NVRAM with socket but it's doing the same thing. CPU gives the same 5 error as well. Even if I have the coin door open and turn it on and off quickly it still just boots into audit mode.
I checked the traces coming off U18 and they look good. U43 and Q52 look good. What else should I be looking at?
