(Topic ID: 157348)
Williams System 9 Display question
By Otaku
8 years ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 8 years ago by Otaku
#1 8 years ago
Hi all, I have a set of original score displays (emphasis on "score": match/credit/ball in play display works fine, looks amazing) that don't work. Somebody on here suggested somewhere to me that operators swapped in dying displays all into one game to save money which I figured is what happened, however now I noticed all of the serials match so this is not the case. If one is going bad, does it burn out the rest of the tubes? I feel like I've heard that before. If not, is this even likely at all? Probably going to try and borrow one to make sure it's not a boardset issue but I'm curious of what caused this.
#2 8 years ago
displays get old and wear out,if one display is going bad it will not affect the other displays...Now if all displays are going bad/fading/ghosting then you need to check the power supply to see if its getting the correct voltage
#3 8 years ago
Quoted from Cycloneman:
Hmm, okay, but I've been told something along those lines by a reputable dealer (although apparently it wasn't burning out just "bad"), and I swear I heard it elsewhere on here.
Even if you're right, I wonder (even more) why they're all dead.
#4 8 years ago
bad ribbon cable/bad power supply..ive dealt with quite a fair number of displays
#5 8 years ago
The displays are independent of each other.
It's possible that your power supply needs serviced and that's why none of them work.
It's possible that your display controller is bad and that's why none of them work.
It's possible they are all outgassed and worn out. But typically, they don't all go bad at the same time.
#6 8 years ago
Update: Tested them all in a known working machine elsewhere and each did nothing, same behavior as on my machine. No glow either, I don't think.
Could it be cold solder joints? They look kind of gnarly. Surprised they'd ALL burn out.
$ 69.00
Pinball Pimp
$ 65.00
$ 18.95
$ 69.00
Pinball Pimp
3,450
Ogden, UT
$ 44.99
Pinball Shark
$ 8.00
Tools
Nezzy's Pinball Prints
$ 36.95
$ 12.50
RoyGBev Pinball
$ 1.00
Pinball Alley
This page was printed from https://pinside.com/pinball/forum/topic/williams-system-9-display-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
