Took a brake from Kiss and went on to "easier" fixes, then came on this.
I have a Williams System 7 that is showing limited CPU activity. In both Leone and Pincoder test(01-a) ROMS I get no activity on CPU pins 16-33, so the entire Data bus. All of the other pins are showing appropriate activity on the CPU. Even when IC9 is removed I get no activity on the CPU legs. I can manually ground the various pins Data bus pins at the CPU and the 7 digit display reacts so it has good continuity throughout the data bus it appears.
Checked continuity between IC1(CPU) and IC9 and IC17
Socketed CPU, IC9, IC18, IC36, IC17, IC13 , IC19
Swapped out CPUs
Replaced IC9
Verified PIAs are good
Thoughts?
