I'm working on a sound board out of a Williams Jungle Lord. It's got the Sound Rom 3 on it. I'm testing this in my Blackout cabinet (both use the same sound board) with the W1 jumper in place, the speech board disconnected and both dip switches set to Off and connector J3 on the sound board disconnected.
Both fuses were blown and the bridge rectifier was bad so I replaced those. Tested 5/12/-12 voltages and they were good. When I press the diagnostic button on the sound board, I can JUST barely hear the audio with the volume pot cranked up all the way and my ear right next to the speaker. The Blackout sound board works fine so it's not the volume pot/speaker. I figured the TDA2002 was bad so I replaced that with a new one and I'm getting the same thing. Went thru and tested resistors in the speaker/volume section of the sound board and everything looked good.
What else should I be looking at that would cause there to be no audio amplification? Would a bad IC13 (1408 D/A converter) cause this?
