Working on a Williams System 6 MPU (Time Warp). It was dead when I got it. Replaced the MPU socket and ROM sockets along with the header connections. Found a bad 6810 at IC13 and installed a socket and new 6810. Removed the battery holder and filled in all the solder holes. Powered it up on my test bench with a computer power supply providing the 5v and 12v. The board boots up into audits mode but it won't go into attract mode. If I push the diagnostic button, both LEDs light solid.
Figured the 5101 was bad so I removed it, tested it and it was fine. Installed a socket and an NVRAM. No change.
At this point I put in Leon's test rom. It boots up with both LED's faintly flashing which tells me it's running. If I push the diagnostic button, both LEDs light up, both go out then both light solid, which points to an issue with the 5101. I checked all my traces between the 5101 and the 6810's and they are good. Tried another good 5101 and no change. I thought perhaps the 7408 at IC12 was bad so I unsoldered it and it tested fine. Put in a new one but no change.
According to Leon's memory test, the 5101 pin 7 (A7) should be at 0v during memory test but it's measuring 2.7v and the 6810 pin 11 (A7/CS1) should be 0v but it's showing 1.1v.
Any ideas?
