(Topic ID: 221188)
Williams System 6 No Display - #Stellar Wars
By sworton
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 3 years ago by pincoder
Williams Firepower CPU Board.pdf (PDF preview)
#1 3 years ago
I am new - so I appreciate any assistance.
My #Stellar Wars - System 6 CPU - has no display on master or player readouts. The master display blinks when I boot up across various digits.
1. I have rebuilt the power supply and verified all capacitors and resistors - all connectors have been cleaned and all resistors on MDB are OK. All soldr points look good on MDB and power supply - Driver board looks good and resistors also check out.
2. The playfield lights up.
3. The MDB has power in 4J 1-7. The -110V and +110v leads all check. The 5V connector only displays 2.7V.
4. The CPU boots fine - may have ROM fail from time to time as but multiple reboot corrects it.
5. I have disconnected all Player 1-4 displays.
Any thoughts on further items to check or potential board fixes are welcome.
#2 3 years ago
Quoted from sworton:
Does it still read low with the MDB unplugged?
Does the game play fine otherwise?
#3 3 years ago
Thank you for your reply - you are most kind to take the time to reply.
It reads 2.7V off the 4J connector - not attached to the board - the Power supply rebuild included 4 primary Caps (C7, C11, C13, C15) and test of all resistors and diodes. I did not repair two caps C9 and C10.
The game does not play at all - no display -
I will say the playfield did not light either until I repaired the Power Supply - now it lights up . Also, the sound board chirps when I turn it on.
From my reading of posts - it sounds like maybe it is the driver board PIA chips but I don't have anything besides a mutli-meter to check things.
#4 3 years ago
Are you sure that connector 1J3 (single wire for display blanking) is making firm contact?
#5 3 years ago
Yes - I checked the connector and jumpered it as well with alligator clips - no dice
Thank you again
#6 3 years ago
What do the CPU diagnostic LED's indicate when you press the test button?
#7 3 years ago
The diagnostics button shows no error - CPU blinks when I power up - no lights stay on when pushing diagnostics.
Thanks for your assistance.
3 weeks later
#8 3 years ago
I have written some test ROMs from scratch that can be run in the game. Give them a try and see if they help you find the problem. The 02-blanking and 07-displays test might help you narrow things down a bit.
You can download them from here: http://pincoder.reversion.ca
There is also a thread on this site where you can leave some feedback: https://pinside.com/pinball/forum/topic/new-williams-system-6-in-game-test-roms
Let me know how you make out!
