Two weeks ago I started a thread, but I have learned so much since that I realise that my subject and description description is worth nothing. So I hope it is acceptable that I start a new thread.
My Gorgar MPU board is bad.
I have read:
Vids bulletproofing guide
Andres system 6 guide
Marks guide
http://www.pinwiki.com/wiki/index.php?title=Williams_System_3_-_7#System_6_MPU_Board_Issues
I have acces to another Gorgar, so I know that everything in the machine works with another MPU board. I also know that I have working ROMs NOW.
Status now is still that both LEDS light up and stay on.
I found and corrected these mistakes:
R33 - dead short - changed
R34 slightly discolored - mesaured fine, but i changed anyway.
C33 slightly discolored - changed
C34 slightly discolored - changed
IC-sockets - gold plated - changed
All sockeded ICs testet (including 40 pin CPU) in other mpu board - working fine except the 3 GAME ROMS (I did not test these individually)
Bought EPROM burned with gorgar image from ipdb.org
Bought EPROM burned with "Andre Boot 2.0" image
Both new EPROMs work in "my" working MPU
I tested all resistors and both resistor pacs inBCD outputs and Strobe outputs.
I do not have a DSR meter only a DMM - so I have only tested capasitors for visual damage and shorts - I have neither.
My defective MPU board, with no socked ICs, except "Andre Boot 2.0" in socket 14, original working RAM IC in 13 and the original CPU 40 pin in IC 1, behaves just like before I started. Both LEDS light up and stay on.
In a workbench (made from PC PSU) with working 5V&12V (tested) i see a comparatible large voltage drop when I connect the board.
These are my voltages in workbench:
TP1 says 11,25V (should be 12V and at least 11,5)
TP2 3,04V (3,68 in my working Gorgar)
TP3 0,05V (0,32 in my working Gorgar with driver board detached, 3,75 with driver board attached)
TP4 0,0V (0,2 in my working Gorgar with driver board detached, 4,75 with driver board attached)
TP5 4,28V (4,5 in my working Gorgar with driver board detached, 4,6 with driver board attached)
TP6 1,97V (2,37 in my working Gorgar with driver board detached, 2,31 with driver board attached)
TP7 3,93V (4,69 in my working Gorgar with driver board detached, 4,69 with driver board attached)
TP8 3,98V (4,65 in my working Gorgar with driver board detached, 4,69 with driver board attached)
TP9 4,06V (4,78 in my working Gorgar with driver board detached, 4,79 with driver board attached)
TP10 0V (0 ohm resistance from ground)
I did not make the LED test board yet, but will as soon my power is high enough for logic to work.
1) Am I right in assuming that I should not expect any kind of results from Test Rom when voltages are that low?
2) Am I right in assuming that I should not expect any kind of logic probing results when voltages are that low?
3) Am I right in assuming that I still have to find a reason for a large power consumption, before I can do anything else?
4) Is it correct that it is always a good idea to replace original electrolytic capacitors c23? I do not have DSR-meter.
5) Should Tantalum resistors c27 & C31 also be changed?
