(Topic ID: 243703)
Williams System 6 GI voltage
By waffen_spain
1 year ago
  • 25 posts
  • 6 Pinsiders participating
  • Latest reply 1 year ago by Schwaggs
There have been 6 images uploaded to this topic. (View topic image gallery).
Screenshot_2019-05-27-21-26-22-719_com.google.android.apps.docs (resized).png
#1 1 year ago
Hi folks!
Im bringing back to life a lovely Time Warp, after solving the typical corrosion at MPU, pin now works great.
Im about to replace GI bulbs with led, but after burning my fingers with a red hot bulb, Ive noticed GI voltage is over 8 volts...
Since It my firts time with a sys6 PS, im asking for your infinite knowledge, do I have a PS problem here?
Bulbs and leds gets lava hot, but bulbs still work after decades....
#2 1 year ago
44 Bulbs get very hot. You can see debades of warped plastics because of this. 47s will reduce the heat a bit and draw less power.
As far as the voltage is concerned there is nothing between the transformer and the lamps but fuses and sockets. Test resistance on the fuse in the holder from one side to the other on the solder tabs. This should be close to 0 but can get higher if the fuse and the clip are tarnished. A hint that this could be an issue would be warm or hot fuse clips.
Then pull the fuses and measure across the fuse clips yellow to yellow. These fuse clips are connected to 17 and 19 on the transformer. This is probably the bottom fuse clip to the one next to it. Make sure DMM is on AC and you should expect 6.3VAC. Might be a little higher without any load. If it's too high it could be the transformer. Check to see if it looks melted or toasty at all. The test from 17 to 19 on the transformer. If you get the correct reading there then you know the problem exists between the transformer and the fuses.
Finally see if there is an inline connector on the GI lines from the transformer to the fuse and make sure those pins don't look tarnished.
It would be good to check another pin of this era to see what the output on the GI line is there
#3 1 year ago
GI should be 6.3VAC.
Take out the GI fuses, then measure the voltage going into them from the transformer, see if it's high there. Might be a short on the PF
#4 1 year ago
Thanks for the ultrafast assistance!
Since the fuses are not marked, and the manual at ipdb says nothing about fuses, Ive disconnected all of them, but GI stays on
Transformer is noisy and vibrates...
As you can see al fuses are off but gi works
#5 1 year ago
Playfield GI is probably the non-fuse all the way to the left and the one to the right of it is backbox. Measure across the bottom of both of those
EDIT: Figure out which the 2 big yellow wires from the transformer go and measure across those 2
#6 1 year ago
Fuse mistery solved.
Some nice guy connected the gi wire to the wires that goes to the fuse, so you have a nice fuse that does nothing.
Im sure he did that """fix""" cos gi fuse keeps blowing.
#7 1 year ago
Testing is done.
Yellow wire from transfo to yellow at fuse holder 8.5v
Yellow wire from transfo to yellow wire at the no fused connector 8.5v
#8 1 year ago
Quoted from waffen_spain:
Testing is done.
Is the transformer hi-tapped?
#9 1 year ago
Quoted from Cheddar:
Im not sure what means "hi.tapped"
#10 1 year ago
On the transformer, see if it's set to 210 or 235 VAC
#11 1 year ago
On a system 6 I think you'll need to look at the 6 wire plug going from the cabinet into the transformer. Upload a picture and we can try to decipher which way it's jumpered
#12 1 year ago
Also put in fuses in line with the AC connection for the bridge rectifiers in the back box (just under the power supply).
You can also use a Bridge Board (http://home.kpn.nl/p.koch3/) and get rid of that BIG capacitor.
Just do some reading on my website link.
Peter
#13 1 year ago
On system 3-6 you move wires on the transformer to deal with various voltage conditions. Tell us which terminals the various colored wires are connected to which transformer terminals.
http://firepowerpinball.com/downloads/PowerWiring.pdf
#14 1 year ago
An easy way to check for high tap is measure voltage at the coils. It will be high too. Not definitive but a good clue if it is
#15 1 year ago
If it's not hi-tapped I wonder about putting a high wattage resistor on the lines to bring the voltage down
#16 1 year ago
Hi! Long weekend far away from my pins
About the Transformer, the jumpers are shown in the photo, not sure if its set to 220, I think It is...
#17 1 year ago
I think that is 220... According to the schematics 117 should have two jumper wires in that plug in addition to the two wires coming in from the bottom, and the 220 configuration uses just one jumper.
#18 1 year ago
Quoted from Inkochnito:
Peter
Man that is some serious tutorial, Im going to check It and mod my pin, thanks for sharing!
#19 1 year ago
Agree, that looks like 220V wiring.
However, to know if your setup is high-tapped, you need to see which terminals those wires are soldered onto the transformer.
#20 1 year ago
Quoted from Schwaggs:
You think that someone messed with the factory wiring on the transformer? Why would anyone do that?
#21 1 year ago
Quoted from zacaj:
If you have a machine in an area with low voltage, bad wiring, etc, the performance of the pops can be decreased, and could cause resets, etc. You can change the wiring to bump up the voltages ~10% to bring back performance. Seeing as his voltages are high, it makes sense to see if someone high-tapped the transformer.
#22 1 year ago
Ahh, I see it now. Note #4 on the schematic
#23 1 year ago
Somebody has been here, I see solder on the transfo.
Looks like wiring needs to be resoldered, but I dont know if its correct.
Comparing the wiring with a pic Ive found from a sys6, looks like I need to change the wiring.
#24 1 year ago
Problem solved, moved brown-red wires from 6 to 8, and black-yellow from 2-3 to 4 at the transfo input.
Now I have 6.8 to 7 volts at bulbs, I have to test coils but looks ok.
Thank you all guys!!
#25 1 year ago
Sweet! Congrats on the fix!
$ 14.00
$ 12.00
Siegecraft Electronics
$ 11.00
Metal-Mods
$ 6.50
$ 67.00
$ 79.95
Hookedonpinball.com
$ 41.00
$ 12.99
Bent Mods
$ 124.00
Hookedonpinball.com
$ 68.00
$ 48.00
$ 9.99
$ 89.99
$ 119.95
Hookedonpinball.com
