Any thoughts on replacing the 40-pin connector that bridges a System 6 driver and MPU with jumper wires to eliminate the connector problems?
Or at least narrowing down which female pins are the culprits and only repinning those on the connector.
Quoted from Brentd27:Any thoughts on replacing the 40-pin connector that bridges a System 6 driver and MPU with jumper wires to eliminate the connector problems?
That's the way it used to be fixed 'back in the day'.
Or should I say 'hack in the day'.
I've seen it done, but nobody will come behind you and attempt repairs. (At least I wouldn't, nor would I buy it unless it was a heck of a deal.) You have to redo the board mounting for the MPU and driver, then decide on which connectors you are going to use.
Never do that.
Excellent quality square pin replacements are available from Great Plains
If somebody brought me a board like that to repair, I would refuse to work on it. That's a hack (and a very bad one).
Quoted from vid1900:Never do that.
For reference, here are the headers you would need:
https://www.greatplainselectronics.com/proddetail.asp?prod=09-48-2106
https://www.greatplainselectronics.com/proddetail.asp?prod=2420-10-2260
This page was printed from https://pinside.com/pinball/forum/topic/williams-system-6-eliminating-connectors and we tried optimising it for printing. Some page elements may have been deliberately hidden.
