(Topic ID: 304429)
Williams system 6 display edge connectors
By frunch
10 days ago
  • 13 posts
  • 5 Pinsiders participating
  • Latest reply 4 hours ago by G-P-E
#1 10 days ago
I checked out my friend's Gorgar this evening and tried to help get to the bottom of a problem with their displays. Turns out the 18-pin female connector that plugs into the right side of the credit/match "master" display board has some screwed up pins. Unfortunately I couldn't seem to figure out a way to extract the pins for replacement, so I've been looking for a new housing. No luck so far--part number 1-640136-8.
Anyone know where I can find one? Or if there's a trick to removing the pins to re-use the old housing?
I suppose my only other option would be to solder the wires directly to the connector pads on the board but I really don't want to go that route if possible.
Thanks!!!
#2 10 days ago
I'm pretty sure I have a couple on spare harness. Let me look. I'll also see how to remove the pins
#3 10 days ago
Post a picture of the old connector housing please. IDC type have no way to replace the pins.
#4 10 days ago
Quoted from PinballManiac40:
I totally forgot to get close-up pics of the connector in question. They aren't IDC, but the was no opening in either side of the connector that would allow me to press down the locking tab for removal. I tried using an edge connector pin removal tool (for gottlieb system 80 connectors) but I couldn't get it to release the pins from the connector (going through the top and bottom, neither way worked). I'll have to take more pics next time I stop over, but it may be a while before I get the chance.
Quoted from Cheddar:
Thanks!!! I really appreciate it. Fingers crossed!
#6 10 days ago
Quoted from frunch:
Not even sure why you would consider this.
#7 10 days ago
Absolute last choice if you can't get the housing....
I had a timewarp where the MDB had normal KK header posts soldered down to the edge connector pads and then a normal molex housing was used in place.
better than wire to board. the problem with doing that is you just made that board and game incompatible with others. And it is a little hacky and potential to rip tracks up if there is a lot of force needed to seat the plug
#9 10 days ago
If it is an AMP 640136 series then some of their sizes are still made (unfortunately not the 18 pin version).
From their website - you can get the instructions for these connectors which includes contact extraction. They list tool number 457241-1 as the proper extraction tool. If you search for this on their website - it shows it as still active but the photo shown is wrong. Click on the Instruction Sheets for proper image and instructions.
Mouser has these but at over $100 each ... ouch! I checked my cost on them... obviously Mouser gets better pricing than me.
The release tip looks remarkably like the Molex 11-03-0016. Might be able to use one of these but this may also require a bit of 'beat and file to fit'.
Often you need to push the wire in from the back before trying to depress the tab from the front. Pushing the wire in relieves the pressure off the tab. If you don't do this, you risk bending the tab so that it will never come out as intended.
Replacement contact is 350011-1.
#10 10 days ago
Think I found a possible solution!
I was considering trying a JAMMA edge connector just to see if it might work. Couldn't find any info here about anyone trying it, but I found a link from someone that was fixing up a Firepower where they managed to use one. I'm ordering a 36-pin (each side is 18 pins) jamma edge connector with solder lugs and I'll see if that does the trick.
http://www.pleasureandpinball.se/fp/fpelectronicseng.htm
Pic from the site:
#11 10 days ago
Quoted from G-P-E:
Terrific info, Ed! Thanks for the help!
#12 1 day ago
I'm pleased to say the jamma connector did the trick! It fits rather tight, but it's working great and with any luck it won't need to be unplugged again for a very long time from the new Wolffpac LED display board. Of course, it was only the day before I went to do the repair that I finally sourced 18-pin edge connectors. In case anyone needs them, this place claims to have them. I've never dealt with this company but if they're legit, they're the only place I could find that sells these right now:
https://www.arcadepartsandrepair.com/store/pinball-kits-parts/pinball-parts/amp-18-pin-bifurcated-leaf-single-sided-edge-connector-housing-as1000/
They also sell the crimp terminals that work with the housing. Thanks for the help, everyone!
#13 4 hours ago
That website is pretty popular for arcade guys and they have been around for several years.
The connector shown is an AMP 1-640136-8. Obsolete and tough to find.
For contacts - use 350011-1
