Working on a system 4 mpu for a friend. when i put it on my factory test fixture (with test rom) all the controlled solenoids pull in (but does boot and go into test mode, I did get 55 55 on the match/credit display once but I haven't been able to replicate it). I put my system 6 mpu that I use for the fixture, all the solenoids are off and test good going through the test prompts. I have reset and blanking on the system 4 mpu, what am I missing? all rom sockets have been replaced, and the 40 pin interconnect also. I had him bring me his solenoid driver board and found a bad pia for the solenoids and replaced that, the pia sockets, and also the 40 pin interconnect. I tested it with my system 6 mpu and it works perfect. so it is something definitely on the mpu causing the solenoids to pull in. also the system 4 mpu was tested and working 100% on my fixture before I sent it off to him the 1st time, I don't know if the bad pia on the driver board messed something up on the mpu.
Edit:
Added a led blanking mod to my driver board that I use on my factory test fixture. Check photos below.
