I have managed to bring a world cup back from the dead but have not been able to figure out a switch related issue.
quick list of what has been done:
rebuilt power supply
rebuilt and fixed MPU
went through driver board all appears to be working properly (40 pin, reflow, sockets, upgraded resistors etc.)
rebuilt sound card
game passes initial board test, will coin up and play; however the switch issue makes it impossible to play a full game.
I did go through the switch test and there are NO switches closed.
I also went through all of the switches and 4 of them do not register in switch test mode, whats weird is 2 of the switches that do not read are duplicate switches in series (the other 2 switches in the series read just fine).
The following switches in the switch matrix do not read:
22 (right switch)
23 (left switch)
13 left ball thrower
25 spinner
I have checked the wiring and all diodes and continuity back to the board and all is good. I even replaced the board connectors just to make sure and no luck.
Issues with game play:
out hole switch 14 reads in test mode but does not register a ball drain unless you also press left eject switch 9
Also Left and Right Ball thrower coils do not activate when a ball is in either pocket. All coils do work in test mode so I know the driver board is working.
I also verified that the 2j3 switch row inputs are not strobing and the 2j2 switch strobes are all strobing. Which should indicate a playfield problem?
I though for sure I would find a bad coil or short but no luck so far, Any ideas?
Thanks for any help you can offer !
