(Topic ID: 222828)
Williams System 3 / 7 Connector Question
By PinJim
5 years ago
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 5 years ago by zacaj
    #1 5 years ago
    Hello All-
    I took in an old Williams Hot Tip (system 3) from a gentlemen, and am working on fixing it. In short, it has a lot of connector issues.
    On the power supply board (connector 3J3, bottom left - see pic), one of the pins has two wires connected to it (6.3VAC). That pin was very damage, so someone pulled the two wires out of the molex connector, cut the end of the connector off, and literally connected an alligator clip jumper wire on the remaining header pin and the 2 wires. Yikes!
    Needless to say, I'm replacing the header and the connector. My question is this: how do I get two wires connected to the same pin? My though initially is to solder the two wires together, with a single pig tail that I'll crimp to the trifurcon pin. I just don't see how I can crimp both wires into one trifufcon pin. Just checking before I do it, as I'm not sure if there is a better or proper way to approach it.
    Thanks in advance for any help!
    James
    #2 5 years ago
    You might be better off installing another fuse holder for the gi off the psu board instead of running it through there again. There's a reason they melted, and Williams would soon go that route on their later games.
    #3 5 years ago
    Quoted from zacaj:
    Thanks - - - that's a great idea. I see on the schematics that the PS is doing nothing with the GI circuit, other than providing fusing. I'll move it off board with external fusing, as I'm trying to bullet proof this machine as much as possible.
    James
    #4 5 years ago
    Quoted from PinJim:
    James
    Both my Hot Tips had already been modded that way when I got them
    This page was printed from https://pinside.com/pinball/forum/topic/williams-system-3-7-connector-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
