I am going to call this project mostly done after working on it for a couple of years. I may do more cosmetic tweaks, at a later date. I will definitely continue to rework the sound packages. Alas, we have a complete platform. MP main (resized).jpg It all started with a cheap project Williams Flash. I thought about the fact that there a few boards in the market place that would allow you to switch game software on the fly via dipswitch. Most folks are familiar with Rottendog and Alltek products. The Rottendog MPU 327 combines the mpu and solenoid driver boards which is great. Then I ran across a few people talking about these French boards being sold out of Germany. Upon further investigation, I discovered that they are actually MPU, Solenoid driver AND Sound boards, all in one! This board would be the glorious Pinball Technologies NW7 pcb. That's what really got my wheels turning. At that point, why couldn't I just put one of those boards in a game and just swap playfields like video game cartridges? I could and I did! All I needed in the head was the NW7 and a power supply board. MP boards (resized).jpg It would all be a piece of cake...let's just say it's been a gratifying journey. Luckily I have some talented friends and there are some great products in the marketplace that allowed me to do it all. Big thanks to Taylor Reese(Reese Rails), David Wolff(Wolffpac Tech), Coos Hakvoort(Bally Bingo specials aka backglass wizard), and Shannon Edens(Edens Creative). In addition to Pinball Technologies, I also utilized to some stuff from Upkick pinball, NMP sensors and Outside Edge.
I currently have four playfields that run in it- Firepower(Hardtop resto with drop target mod), Gorgar(Hardtop resto), Flash(future Hardtop resto), and Hot Tip. I will elaborate on each of them in separate posts. First, more on the basic system. The NW7 allows you to change sounds, similar to Pinsound. It also has a jukebox function which allows you to play music or background tracks when the game starts. You can have a lot of fun with these features. The other great thing about the NW7 is that there is a stereo speaker output option. The Flash cabinet had one, down firing, cheap speaker like all the games around that time. With all of these sound options available, I had to do something about the speaker set up. I got the idea to take a Firepower 2 style speaker panel which originally had a single speaker in the center of it and cut out holes for two speakers for stereo. I picked up one these speaker panels on ebay or somewhere. I was able to have a sign shop reproduce the plastic element that is on the front of that panel. Taylor Reese actually took this panel and made a new reproduction with routed openings for the stereo pair of 6X9 speakers. I painted it and it all went together perfectly. speaker panel (resized).png
Using that speaker panel created a new challenge for me. The Flash back box was designed to use a Williams early SS full size backglass. I then had to cut out some wood and add some new sections to support using this panel. I also had to add hasps to lock it into the head like it did originally in FP2 and the like. Next I acquired a Firepower 2 light insert panel to go with the speaker panel. Getting the correct position while installing that was a pain but I got it done. Now I'll just throw these six digit displays in this system 7 insert panel...wait, this display driver board/credit and ball display will not fit on the frontside of this insert panel. So, this is where David Wolff sent me some options to work it out. Firepower finished (resized).png The solution was to mount the driver board on the back of the insert panel like a System 7. What this meant was I had to hardwire a credit/ball display that was mounted on the front side to the actual holes on the driver board where the individual numeric units would be soldered in. display driver (resized).png
I know this is getting long winded. Playfield compatibility ended up being easier that I thought on the wiring front but harder on the fitment front. I only ended up having to moving a pin or two in the playfield side of the wiring harnesses to make them work in the Flash cabinet. However, I had to cut out some notches in the playfield support rails to make room for certain mechs. I also modified a Stern 4 chime unit with with coils of correct voltage and fitment to play Hot Tip. Oh, and don't forget the dummy score reel like they used in the original SS Hot Tip. MP chimes (resized).jpg Ok cool, I have all these playfields working in this cabinet. I need a custom backglass! I poked around for someone to help me with art for it before I realized the person I needed for this was right under my nose. Shannon Edens had already done some design work for our pinball club. I thought we could take the basic layout from the Firepower 2 backglass and tweak it. Shannon did a killer job and then Coos worked his magic to make a fully legit, mirrored backglass. MP back box (resized).jpg Alas, I present the Williams System 3-6 Multi-Pin!
