Hi all
Trying to figure this out. I've got a 2nd replacement right display that was said to be working but I've never seen it work. Is there any way I can test to see if the display works or if the system is not sending the signal?
Matt
Hi all
Matt
It should work. The left display should be segments 1-16 and the right display should be segments 17-32. The strobes are shared between the displays.
Sorry. You're right. I have experience with the double display but not the separate L/R displays. The schematic wiring shows that the L display only looks at segments 1-16 coming in on the ribbon cable and the R display only looks at segments 17-24 on the additional connector as well as segments 25-32 on the ribbon cable.
If you have another System 11B (double alphanumeric) display you can connect that to the CPU board and see if it works.
This page was printed from https://pinside.com/pinball/forum/topic/williams-system-11b-only-left-display-works and we tried optimising it for printing. Some page elements may have been deliberately hidden.
