Hi.
I am trying to help a friend troubleshot a System 11B board that does not boot, board is a bit of a hack job, had some acid damage, and a bunch of parts replaced.
Here is the problem, board seems to do its thing with the Leon test rom, Pia's are pulsing, reset circuit is good, irq signal, vma, clock also good, relay clicking, with game roms the trouble starts, diagnostic led flashes around 60 times, then blanking led 10 times, and it starts over, no difference if ram or U26 is installed, same behavior.
All Pia (6821) has been replaced, and are socketed, U25 ram has been replaced, U26/U27 has been replaced, sockets for U25/26/U27 replaced.
Never worked on a System11 board before, so i am a bit stuck, any help will be appreciated.
Edit: Got it to boot one time, but no luck since, fault was the same before parts got replaced.
