8/21 UPDATE: FIXED-Cabinet switches needed readjusting.
The PCB was sent off to Allan Davidson who did a tremendous amount of work to it and it is looking aces. I powered it on and all was great until I went to start a game and the left coil locked on and the right was dead. Any ideas where to start looking.
I picked up a hot mess of a Fire! last month. Prior to my repair attempts the flippers had been working. Just not the slings, prior owner installed the diode backwards on the lowers and took out the transistors. It looks like there was damaged to the area prior as some chips were socketed and others had jumpers.
I replaced the associated lower sling transistor and pre driver, and socketed and replaced U50. Whoever removed and worked on the PCB prior was very heavy handed with the heat so the backside was a mess of lifted pads and traces.
Now when I fire it up, I still don't have any of the special solenoids AKA upper and lower slings and the flippers no longer work. All the fuses check out. Nothing fires during test mode.
I found this explanation that these solenoids are controlled by U50 and author states U45: https://pinside.com/pinball/forum/topic/system-11-special-solenoids#post-4810138
So I guess I should go back and check my work on U50 and verify the incoming voltages. Before I go probing, How do I determine the input location. I know after years I should know better, but I have shaky hands and I've always been hesitant about probing chips. My guess is I have a dropped line somewhere on U50 from a bad pad or trace.
"You can check this with the board installed, the game in test mode, and J19 unplugged, measure the input voltage to the NOR gates at U50 and U45. You should see a near 0 volts at the input off of U56, and the other input coming off of SR20 should be +5v if things are working correctly."
201596023_10159174362046271_6537842659308348482_n (resized).jpg201751132_10159174362191271_4031618672461583473_n (resized).jpg201915639_10159174361901271_4080265449279746029_n (resized).jpgb326e4b7e20df9513cf9c4b1cd64a496b16208e9 (resized).jpg
