Hello folks -
I have a Taxi that at some point in the past had a system 11 board installed (from Road Kings based on the factory stickers).
Research indicates that six zener diodes must be added (Z3-Z8) to the board to have special solenoids work as well as grounding two connector pins. This board has several zener diodes added to the board but originally had no pins grounded. I did the grounding mod and lo and behold my bumpers started to work.
All well, but then...
One day in the middle of play, several solenoids kicked at once and two of the bumper coils locked on. Testing the special solenoid section revealed a couple of bad drive and pre-drive transistors, which I replaced, as well as a shorted D3 diode. Replaced these components, but the two upper bumpers continue to both lock on when the game is turned on. Unplugging the special solenoid connector from the board makes everything normal.
No switches are stuck. Can't see any ground issues with switches.
I am wondering if one of those diodes added to the back may be shorted, but no one seems to have explained the actual location as well as logic behind this addition, and what values one should see when checking the components.
Please advise - thanks!
-scott
