Hello all,
Can i use the system 11 mpu from a Grand Lizard to replace the system 11c that the Rollergames came with?
Hello all,
Don't, 11s are rare and you'd have to do some work to it. Much better to go out and find an original C instead. Someone is dying for that system 11 board.
Read https://www.pinwiki.com/wiki/index.php?title=Williams_System_9_-_11#MPU_Driver_Boards for more information.
Quoted from PinballManiac40:Is your original system 11C board damaged or missing? If damaged, post a picture of it.
Honestly, i don't know if there is anything wrong with the 11c mpu. I have not played the Rollergames in quite a while. I turned it on the other day and all i got was the general illumination lights. No display and no "bong" sound on power up. When i press the button on the side of the mpu it will "bong" and briefly displays "mem protec failure". I am just barely getting into trouble shooting this one. All three red lights are continuously lit on the mpu. The reason that i was asking about possible sys 11 compatibility is that i have a "Grand Lizard" that had been retired years ago. The mpu is in it but i have no idea if it is any good. Someone got to the other boards before i got the machine.
The display is totally blank and appears to be dead until i press the button on the mpu (11c) thats when it displays the "mem protec failure" and then goes blank again.
Quoted from TxDremz:mem protec failure
Start with posting a picture. If there is no or minor battery corrosion, then board is repairable.
Quoted from PinballManiac40:Start with posting a picture. If there is no or minor battery corrosion, then board is repairable.
Here is a couple of pics. I have not removed the mpu but i don't see any obvious problems. I am going to be digging into this deeper tomorrow with a multi meter. What besides checking fuses should i be looking for first?
Thank you, by the way. Oh yeah, You might notice in the picture that the ribbon cable above the batteries is missing. I unplugged it for a better shot of the area around the batteries.
Thing is clean as a whistle as far as battery corrosion goes. The fix should be cheap and easy. If I were you, my bigger concern would be finding the other boards for the Grand Lizard.
Quoted from TxDremz:What besides checking fuses should i be looking for first?
The battery holder is bad and I would also replace C-30 while the board is out. Then put it back in and check voltages on the power supply.
I could install NVRAM for you to keep that perfect MPU looking like that forever, which removes the batteries. I even have the C30 and night even have all capacitors on hand for a cap rebuild for that power supply. I live out close Katy. Also, Tim in Cosby of Crosby Pinball could also do it since he is less than half the distance than I am from you.
Quoted from GRUMPY:The battery holder is bad and I would also replace C-30 while the board is out. Then put it back in and check voltages on the power supply.
Thank you. I will replace the battery holder with an NVRAM as well as the C-30. I have both of them on hand.
Quoted from PinballManiac40:I could install NVRAM for you to keep that perfect MPU looking like that forever, which removes the batteries. I even have the C30 and night even have all capacitors on hand for a cap rebuild for that power supply. I live out close Katy. Also, Tim in Cosby of Crosby Pinball could also do it since he is less than half the distance than I am from you.
Yeah, If this thing gives me too much grief i will be giving Tim a call.
I will update with my progress. Thank you!
This page was printed from https://pinside.com/pinball/forum/topic/williams-system-11-system-11c-compatibility and we tried optimising it for printing. Some page elements may have been deliberately hidden.
