(Topic ID: 273632)
Williams system 11 sound issue
By finnflash
16 days ago
  • 22 posts
  • 2 Pinsiders participating
  • Latest reply 6 days ago by fixintoplay
    #1 16 days ago
    I am having an issue on Earthshaker where one of the call outs is very, very slow. Almost like its running on dead batteries.
    Do I need new sound roms or is this a board issue?
    #2 16 days ago
    Try this 10-minute low-hanging fruit checklist to start ruling out suspects on that system 11B by working thru the sound paths. Maybe there’s resistance on one pin somewhere. Try reseating the ribbon cable connectors between the MPU and audio board. Then remove each rom from its socket in the sound section of the MPU (while in situ), gently clean the rom pins with a soft brass brush and reseat. Then move on to the audio board, do the same to the roms and reseat everything. For me, it was easier to remove the audio board and reseat all connectors when I did this for sound-related troubleshooting. Could keep you from buying parts and extra board work you might not need.
    #3 16 days ago
    I will try this. Thanks
    What is situ?
    #4 16 days ago
    In situ: in place; without having to move or remove. My tech writer habits creep in sometimes.
    #5 15 days ago
    Unfortunately this did not help.
    What should I do next? Would buying new sound roms help?
    #6 15 days ago
    I assume you’ve run sound tests? Audio board and general system? Check your manual for the procedures which could identify malfunctions.
    #7 14 days ago
    How do I test lights or sound?
    I can find audits and adjustments, but it ends there.
    #8 14 days ago
    Page 35 describes the audio board and sound circuitry tests. Test #2 describes the sound diagnostic switch SW1 on the left Lower edge of the CPU which checks voices. In your OP you mention “call outs” so I’m assuming that means voices.
    #9 14 days ago
    I don't have a manual so I didn't realize the test switches in the back.
    When I hit the sound test, it just beeps 3 times over and over.
    When I hit the cpu test I get this on the display.
    #10 14 days ago
    I thought you had a manual. Before you test or post anything else, get one in front of you. It's the book of secrets. You'll need it to understand how your machine works and how to keep it in good working order. It's available free to read and/or download at:
    https://www.ipdb.org/search.pl?any=earthshaker&search=Search+Database&searchtype=quick#753
    Find and click: "English manual" in the IPDB listing. I downloaded, printed and bound mine for Jokerz! (virtually identical to yours), which I refer to all the time. You're lucky -- Earthshaker's pdf is much clearer than the fuzzy Jokerz file, so I use yours more often.
    If you had a manual, you'd know what those "three rings" mean. They're significant. And it's defined on page 35 under step 2, as I spelled out in my last post. I could easily tell you, but I'd rather help you find it yourself. It specifically addresses your issue. This is why I find fixing pinball machines more gratifying than playing them.
    #11 14 days ago
    Thank you for this, I searched for a manual for a while with no luck. I am on it.
    #12 14 days ago
    Ok, manual says 3 beeps means U4 chip problem. Would replacing that sound chip fix it?
    #13 14 days ago
    No. You're not reading this section correctly, but you're trying. That's good. U4 is on the Audio Board and is not part of the SW1 switch test you ran - the game does that test automatically at start-up. You should get one tone at start up which indicates "system OK". Do you? If so, that means the audio board and U4 are fine.
    Move to the next 2 paragraphs about the SW1 switch test you just ran. What does it say about the "three or five rings" you heard after you pressed that switch? It tells you the problem ROM chip: U22. You probably already reseated it in my earlier checklist. If so, replace it. Next, you'll need to address the display message in your pic when you ran the SW2 switch test: MEM PRO1 FAILURE. The chart on the top of page 35 explains what conditions are causing it. Read note 1 too. You should now have most of the information you need to fix your problem. You'll get there.
    #14 14 days ago
    Ok, so I misread the beeps on boot up as SW1 test results. I am getting 1 beep at boot up.
    Ran SW2 test with coin door open and did not get a failure back.
    Going to replace U22 chip per SW1 test.
    Thank you for the guidance
    #15 14 days ago
    Post your results. You're doing great! Never played Earthshaker, but I hear it's a great game.
    #16 14 days ago
    Thanks again, will post once I get the rom.
    #17 7 days ago
    So I put in a new U22 chip, and I ran the SW1 test. It still beeps 3 times indicating a problem with the U22 chip.
    Not sure what to look for now?
    #18 6 days ago
    If it’s installed the correct way, it could be the socket. Perhaps reflow; replacement requires special board skills. I would try starting a new thread using the U22 chip issue and what you’ve learned so far. There are System 11B gurus here who would have deeper experience and advice on this.
    #19 6 days ago
    Thank you, the socket was my first thought. Does reflow just mean to heat up to fix any cracks or add new solder?
    #20 6 days ago
    Should have asked, did you try playing a game to check the sound?
    #21 6 days ago
    Yes, its still doing the samething.
    #22 6 days ago
    Unless you know what you’re doing, you could damage the fragile traces. Try searching the forum to get up to speed. Best way is to remove old solder first. Plenty of opinions. Depends on your skill level and confidence.
    Playfield - Plastics
    Pinball Mod Co.
    $ 96.95
    $ 1,000.00
    Playfields
    Pinball Playfields
    $ 8.00
    Docent Electronics
    $ 245.95
    Allteksystems
    $ 16.95
    $ 239.99
    PinballBulbs
    $ 235.00
    RS Technologies
    Filament Printing
    $ 86.95
    $ 5,799.00
    Nitro Pinball Shop
    $ 154.00
    Id Rather Play Pinball
    $ 74.00
    $ 36.00
    Pin Monk
    $ 25.50
    $ 14.95
    $ 40.00
    Arcade Arts
    $ 48.00
    $ 76.95
