(Topic ID: 264196)
Williams system 11/Rottendog replacement MPU
By sbraymen
  • 4 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by barakandl
#1 4 years ago
I just want to share my experience with the Rotttendog MPU 92111 for the F14 Tomcat. Although my pin booted up with out errors with this board, I was missing sounds 0 thru 7. I tested and tried everything I could find in the online blogs, but I couldn't resolve the sound issue. The one thing I did finally do was swap the 6802/6808. U42 with the U10 processors. With these swapped, the machine failed to boot, indicating the processor originally in the U42 location was bad. This was a Motorola brand processor. The U10 was a Hitachi. I replaced the Motorola with a Hitachi processor and the sounds 0 thru 7 began functioning. I don't know if the Motorola was bad or if it just didn't work with the Rottendog board, but the Rottendog is now working for me. The original F14 board was roached. Between the battery acid and mouse urine, I had to replace it. I made the assumption that the chips were otherwise good. The displays did not work, but replacing the 4001 and 4005 chips it works fully. Thinking back, maybe I should have concluded early on that maybe this machine had taken a voltage surge that killed not only the displays, but also the processors. Some of the blogs indicate problems with the Rottendog product. I would recommend that salvaged chips are replaced first with known good ones, before blaming the board. Thank you for listening.
2 months later
#2 3 years ago
Thank you for posting your experience.
Out of curiosity, do you have any issues with distortion of sound/loud static associated with Rottendog boards in System 11 games?
2 months later
#3 3 years ago
I would think that most sound issues for the F-14 can be solved by this thread. https://pinside.com/pinball/forum/topic/system-11-sound#post-5782536
I changed out the resistors on my sound board and I think that it made a big difference with the MPU911.
#4 3 years ago
I don't know how rottendog does it but there is a 6802/6808 CPU brand select jumper that is different for Hitachi vs every other brand when an external complete oscillator is used (like sys 9/11). For hitachi the 2nd clock input pin floats. In Moto, ST, SGT, etc that pin is grounded. If its not set right the CPU may not run.
Original poster's issue could have been not related to that, but worth mentioning.
$ 69.00
Pinball Pimp
$ 18.95
2,100
Rancho Cucamonga, CA
5,000 (Firm)
Vandalia, OH
$ 1.00
Pinball Alley
Flashinstinct
$ 2.50
$ 65.00
arcade-cabinets.com
$ 18.00
$ 5.00
Metal-Mods
$ 39.99
Fort Lauderdale, FL
$ 65.00
$ 36.95
$ 19.99
Cedar Rapids, IA
This page was printed from https://pinside.com/pinball/forum/topic/williams-system-11-rottendog-replacement-mpu and we tried optimising it for printing. Some page elements may have been deliberately hidden.
