the game is up and running but seems like pop bumper lights and all other lights on top right corner of play field are not working. all bulbs are good and pop bumpers work. just no lights in that corner. any one ever have this problem? thanks
Quoted from TheDude:Pull em out and put them back in again.
Re-seating the plugs sounds like a good idea.
if i bring power to one of the sockets they all light up but do not flash like the rest of the play field.do you think this is a mpu board problem?thanks
Sounds like a bad connection but it could be a bad switching transistor as well. You need to check for current starting at the lights and work your way to the power supply. Test at every connection and component until you get a current reading. It's the process of elimination....Do you have a wiring scamatic for this machine?
Post edited by jrrdw : Added contant.
i have the manual but i'm not good at with that stuff.i'll check if there is power at the power supply board at the connector.thanks
Quoted from oldschool:snubber 5768-11095-00..
Check it from pin to pin. Test the traces that way.
Quoted from oldschool:i have the manual but i'm not good at with that stuff.i'll check if there is power at the power supply board at the connector.thanks
Did you ever figure out the problem? Have same issue. Thanks, Dave
This page was printed from https://pinside.com/pinball/forum/topic/williams-system-11-light-problem-pinbot and we tried optimising it for printing. Some page elements may have been deliberately hidden.
