Hello All,
Running into a few issues with my Diner tonight. I just installed pinballbulbs no ghost LED thought the machine. I keep blowing a 5amp fuse which causes me to loose the left hand side G.I. and pop bumper lights. It doesn't happen right away. It only happens when either of the top out-holes kickers launch a ball out. Besides crossed or exposed wires is there anything else I should check for? The switches test fine in diagnostic mode and I don't see any GI wires touching the solenoids or anything. Is it possible that the circuit is drawing too much power causing the blow?
Also I'm running into an issue where a few of my LED flashers strobe slightly when ever I hit the flipper buttons. I read about removing the warming resistors but wanted to see if anyone had experience doing this on a Diner. Not really sure which ones to remove. Its only 2 customers and the '10x Scoring' arrow but still a bit annoying. I don't believe I have a warming circuit mounted under the playfield.
Any help is appreciated. Thanks !
