Hello,
I re-enter a topic to merge 2 questions I had inputted, for which no solution was found.
On my Jokerz!, the vertical ramp of 8 lamps indicating the jackpot amount on the backbox insert does not work (see picture). All lamps are dark while playing and in "all lamp test" mode.
I came to the conclusion that the strobe 8 of the lamp matrix has a malfunction. I connected a #555 bulb on a socket directly (with a diode between the lamp and the pin) between 1J7 - 9 (strobe 8 ) and every pin of 1j6 (rows), the bulb never went ´on'. Also measuring the voltage on 1J7-9 gives 0, where other pins on 1J7 show positive voltage.
I found no anomaly when checking Q52, Q51 with the DMM, setting "diode" and none with the continuity. I replaced Q52 anyway by a TIP42C, in case of, but no effect.
Then, I went upstream to the IC U52 (TTL 7408) and checked the inputs and outputs with a logic probe and DMM. This IC contains 4 "AND" gates (the one with pins 8,9,10 is the one which drives strobe 8 via the transistors).
On UC52, the 2 input signals for all gates are consistent (high for blanking, and pulse for the second input). The outputs are similar except the one that I am interested in, i.e pin 8 gives a result different from the output of the 3 other gates. With the DMM, it gives 0,72Vdc whereas the others show 0,32 Vdc.
For a complete comparison, I made the check on my Cyclone which has a similar set of lamps for strobe 8. The voltage check of U52 pin 8 on the Cyclone gives the same value as the other outputs, i.e. 0,32Vdc, hence not the same value as the U52 pin 8 on the Jokerz!
Finally, and I am back to the JokerZ!, the output lug of Q52 shows no voltage as the 7 other transistors commanding strobes 1 to 7 do.
Hope to be complete in my description, I am wondering how to find the part in default.
Your help is welcome, thank you
Thanks in advance
