Quoted from Prospekteur:Can someone make an shot of the back of the coindoor, where I can see where the wires from the middle microswitch are goin to? Especially the red wire of the rearmost contact of the middle microswitch. Mine is loose on the other end, and I need to know where to solder it.......
Here is the wiring diagram from the manual. The switch closures only need to satisfy the wiring requirements. Note that the coin slot switches are on the switch matrix in System 11 and require a blocking diode.
Have you considered posting images of your door that:
- are well lit
- are in focus
- are from multiple angles
- include wiring to the cabinet harness
If you do that you might get a better response. When I see that image ... it is blurry, grainy and out of focus. Why should I bother spending time to help you when you haven't spent any time trying to help someone who wants to help you?
