(Topic ID: 101502)
Williams Super-Flite EM (1 target strike lights others on the playfield)??
By nstigator
5 years ago
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 5 years ago by CactusJack
#1 5 years ago
Hey guys... could use some help here!
I aquired a really nice Super-Flite EM the other day. Home-owned for the last 25 years, so not a whole lot of abuse!
Heres my problem. It happens probably 90% of the time, and the other "random" 10% it doesnt.
On the playfield you have A,B,C, and D targets.
When the machine is in "90%" mode... lol... if i hit the middle "D" target it will also trip the relay for the middle"A" target. Also, if I hit either the top or bottom "A" target... the middle "A" target will light and the relay will trip. The "B" and "C" targets work exactly as they should 100%.
With that said, on occasion I'll play and they all will light individually just as designed.
Where should I start looking? Any ideas?
#2 5 years ago
There are 12 trip bank relays for the A B C D targets. Each relay has a Make/Brake (Normally Open and Normally Closed) switch associated with the Playfield Target switch. When reset, the playfield target powers the trip coil of the relay through the Normally closed switch. Once the relay is tripped, it routes the power instead through the Normally Open switch (now closed) to a common line going to the 50 point relay (A and D targets) or the 100 point relay (B and C targets). This is why when you hit a target really fast, you get the letter but might not get any scoring (typical of any Strato/Super flight).
So it is possible, if the NO switch is sitting closed AND, the NC switch is also closed, any of the fellow targets could trip other targets that share the same scoring.
Since this is happening intermittantly, I suspect that the RESET bar is not always returning to a fully retracted position and leaving one or some of the make/brake switches as all three blades connected. So, you might want to check how freely the bar can move back and forth or if there is something like a wire harness hanging in the way.
$ 4.49
$ 4.49
$ 5,899.00
Classic Game Rooms
$ 29.95
Pinball Photos
$ 89.99
$ 24.95
The MOD Couple
$ 26.50
The MOD Couple
$ 9.99
$ 5,899.00
Classic Game Rooms
$ 38.00
$ 18.99
$ 39.99
$ 5.00
Doc's Pinball Shop
$ 299.99
$ 40.00
Arcade Arts
Operation Pinball
$ 8.95
$ 57.95
PinBoss Mods
