(Topic ID: 198321)
Williams Start Up Issues
By Kickout
6 years ago
#1 6 years ago
1968 Lady Luck. At start up the Score Reset Re. Continues to energize and will not stop. The Credit Wheel continues to deduct credits and the Score Motor runs constantly. Checked all switches all in the correct positions. Not all Drum units will reset to zero at start up. Have cleaned and checked all Drum unit switches several times. Set drum units to zero manually and the Score Rest, Credit Wheel and Score motor still continue to try and energize and will not stop.
WHAT AM I MISSING?
Kickout
#2 6 years ago
You'll need to check the switches that send power to the score motor. First, check to make sure the coin chute switches are open and not stuck in the closed position. Check the following relays and their switches to make sure they are adjusted properly.
Delay relay
Eject relay
Player reset relay
No 1 relay
No 2 relay
Reset relay
Coin relay
Outhole relay
25 cent relay
10 cent relay
Score motor switch IND-E
Also check the wire lugs on the switch stacks to see if they are shorting...
This page was printed from https://pinside.com/pinball/forum/topic/williams-start-up-issues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
