Went and checked out a '71 Williams Stardust. I played a couple of games and it seemed to function properly so I bought it. Got it home, put it together and plugged it in but have yet been able to make it work. Pressed the left flipper button and all the lights came on. pressed the start button and heard the motor cycle once and then nothing. Lights will come on but nothing on the playfield works with two exceptions. The down post buttons will activate when contacted and the eject cycle will perform when the ball is put into either of the two capture holes. Other than that, it is dead. Flippers do not work, bumpers do not work, etc.
I'm guessing something happened during the take down/move/re-assembly, but I have checked everything I know to check and can't really find anything that doesn't look right. I put all new fuses in it and I have also checked them with a DMM so I know they are all good. I can add scores to the wheels and then manually operate the relay and it will do a reset. I can activate the motor manually and it will cycle. It just seems that a portion is dead.
Anyone have any pointers on what mught be the cause? I'm sure there are hundreds of possibilities. LOL
I do have some experience and coursework on electronics theory, troubleshooting etc. but it has been a long time since I have "practiced". I'm pretty sure I can fix the unit if I can get pointed in the right direction.
Any help or advice would be most appreciated. I really want to get this thing going for my grandchildren's playroom.
Thanks in advance.
