(Topic ID: 102057)
Williams Spanish Eyes Free Play
By 04barb
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by EMsInKC
#1 4 years ago
On my Williams Spanish Eyes, I'm trying to get it to free play. I have the replay counter's top two contacts closed, like I read I should but still I need to use quarters. What else is in the circuit that could be causing this issue?
#2 4 years ago
If you move the replay counter "Credit Reel" off zero, do you still require a coin?
The idea to make it free play is to close the the zero SW, while it is at zero.
On the Credit Reel there is a make/brake SW. you need to make it so the White/grey wire makes contact with the White/Orange wire. Use a jump wire and wrap around the solder lugs of both wire mentioned above.
#3 4 years ago
Also, try putting a piece of paper between the other side of the M/B SW just in case this is causing problems. So open white/grey wire to Black/Red wire side of the SW.
Once you have it sorted, you can do a more professional fix.
#4 4 years ago
With no replays showing, I closed both sets of contacts on the replay counter. I still need quarters even if I have replays showing or not. I will try to jump together the white/grey and white/orange wires. Hopefully the contacts are cruddy and if I jump them together that will fix the free play issue. If the other side of the make break switch is shorting out on the other set of contacts, that would causing my issue as well?
#5 4 years ago
Quoted from 04barb:
Just cause they touch doesnt mean they allow current to flow.
Clean the 2 upper contacts for continuity.
http://www.pinrepair.com/em/index3.htm#free ← Seen here Red arrow.
#6 4 years ago
Have you actually checked the start button to make sure everything is good there?
750 (OBO)
Sylvania, OH
Pinball Wheezer
Various Other Swag
Project Pinball Charity
$ 19.95
$ 5,799.00
Flip N Out Pinball
$ 48.00
$ 135.00
Metal-Mods
$ 21.00
$ 65.00
Texas Pinball
Operation Pinball
Metal-Mods
$ 48.00
$ 29.99
$ 229.00
$ 7,499.00
Little Shop Of Games
Metal-Mods
Pin Monk
$ 239.99
PinballBulbs
$ 28.95
Hookedonpinball.com
$ 18.99
