Well hopefully I can explain this right.
I have a Space shuttle that all the boards have been sent off and fixed, after getting them back everything worked except the slingshots, after some tests I replaced the coils for them, still no workie.But for some reason the fuse will blow evertime I turn the machine on.
I removed the ground plug from the main board and turned on the machine and the fuse stays good.Then I one by one touched each ground back to its coil and the fuse stayed good, I shut the game off reattached all wires to the coils and turn it back on and blew the fuse, what am I missing? All coils read around 5 ohms, voltage is around 22 -24 volts.
